Wanted a new control panel for a long time, now it´s almost done.
This is a prototype of the layout. I have ordered a new button-pad, thats why it looks crazy with the old one still there :slight_smile:
Temps showing PSU temp, water tank temp, and the third is for the 2nd loop outside the window with a radiator.
With theese buttons i can controll red dot, lights, fans, air assist, water pumps, exhausts and autofocus without scattered buttons or glued buttons on the old panel :slight_smile:
Very nice did you make an entirely new sheet metal door. This is not a K40 (the depth of the cover)?
It´s a K40.
I cut out a large area and inserted a acrylic panel in the metal lid and wrapped it with vinyl :slight_smile:
Going to wrap rest of the white metal in the same color.
The black piece with buttons is just a thick vinyl sheet too.
The front lip on the doors are much bigger than mine? Did you cut the front of the cabinet?
Nice job on the switch/meter panel.
Same as Don, the front of your doors are also much larger than mine. I think mine is only about an inch high on the front of the doors.
Ah, yeah its the upgraded/newer version of K40, sometimes refered to as K40D. Inside is upgraded aswell.
Wait… autofocus? :slight_smile: Im listening…
Arduino controlled stepper motor moving the lens until the sensor touches the surface. The sensor is on a pre-set height and after that it backs off 3 revs so the sensor isnt dragging on the material.
The system knows where the exact height (focus) is to cut or engrave.
It´s not actually checking the optic focus, it just moves the lens to a pre-set distance i measured.
Had it manually earlier, but it was cool building it motorized.
No matter what thickness on the material i use, one button and boom, it´s in focus.
First prototype is working now, i´ll post a video of it tomorrow :slight_smile:
@HP_Persson You mention that it doesn’t matter what thickness material you are using, so does that mean you have to reset a “thickness” setting for different thicknesses? Because say 6mm thick compared to 3mm thick is 1.5mm difference in the focus point…
Seems like a great idea though :slight_smile:
I´m working on making it to count revs/steps properly away from absolute zero (home) to identify the thickness with 0.1mm resolution, as you mention what i described only works for engraving :slight_smile:
System knows were zero is, and when the sensor stop it using the calculated amount of travel done it “knows” what thickness it is and can move the lens to a proper focus.
So far only coded a small piece of this in 0.5mm resolution , but i´m getting there :slight_smile:
Not yet found a better solution than counting steps to perform it, if someone has a idea i´m glad to try it out :slight_smile:
Quick pic without the lens/sensor/red dot/airassist assembly.
(and no, the final version will not be 3d printed, but aluminium or brass :slight_smile: )
