I asked the seller of the PrintNC if he could do better than his posted price of 1,200$ he said he was pretty firm on the price. A problem was he is around 400mi away and thinks shipping would be costly at 200lbs and numerous boxes.
I found another producer of PrintNC Kits that have CNC milled parts instead of printed ones and uses Stainless for the frame. Lead time is up to a month and another month for shipping via sea freight. I may want one of them at a later point or DIY from parts.
I found another CNC very close to me. It’s a Chinese made 4030 or 6040 I think. One of the heavier duty models that can do metal the spindle isn’t water cooled but it looks like a 500w or so and has a Buildbotics controller (not sure what that is ATM) but I’ll look into it. I’m going to see if I can go check it out in the next few days.
I looked at the reddit link briefly. I understand the idea of “buying my second CNC first” and also the saying “you build you’re second CNC with you’re first”
I may just want to get a cheap 4040 to start. My first projects will be producing RC Airplane parts from Balsa wood, Light Plywood, thin fiberglass/carbon sheet and up-cycled aluminum beverage can aluminum and polystyrene foam.
A the second “category” of parts I want to make are custom bicycle parts specifically Fork Triple Tree clamps and moving into engine parts and things like wheel hubs etc.
I would like a lighter duty 4080 for the RC plane stuff.
A separate machine for the heavier metal parts. That could be a 6040 or even smaller probably with a 4th axis.
Another would be a good size machine like the PrintNC to make furniture. I could go to a local Maker Space for that though and likely would at least to start those projects.
After that would want something that can do large metal parts like a decent size industrial machine.
I don’t know if I mentioned but I did operate a CNC back around 2014. It was at a former Maker Space I was a member of. I think the machine was a DIY 4x8’ plywood machine. They overheated a spindle and I waited for it to be fixed. They got a new spindle but left the cooling system unchanged. I forget what I did but I somehow fixed the overheating issue before they let it happen again.
I think the software was called Dolphin?
My first project was a mock paramotor propeller from a scrap 2x4. It actually was really nice with the exception that I assumed the machine had a precision axis/level bed and didn’t adjust part levelness for the second side cut and one blade was thicker than the other.
Anyway I know there will be a good bit for me to learn even on a small inexpensive machine but I’m pretty sure I’ll learn quickly. I got into 3DP at the same time then bought my first printer about 5 years ago and have been printing kind of a bunch since.
I’ve used a Laser and picked that up in approximately 2 weeks including SVG production in Inkscape.
I imagine 3D CNC will be closer to 3D printing than Laser operation in the learning complexity.
