Want to change the PIN configration
Dear Sir,
Thanks for quick response for previous question
I want to change the PIN configration because I am using MBed with different Board so I have different PIN configration. After installation I found PINS for Extruder and SD Card under (main.Cpp) but could not find PINS for X,Y,Z and end switches, where could I find them please guide me.
please guide me.
Hope to hear you soon.
Regards
Talib Hussain
Imported from wikidot
Hi !
You need to use a configuration file on the SD card, like here : http://smoothieware.org/configuring-smoothie
Regards !
Hi,
Is it already existing file(config. file) or I have to make it completely from scrach.
Regards
Talib Hussain
You can use the config file in the wiki page, just change the pins for your configuration.
