I bought 30 gallons of distilled water as part of my pickup. They were like what the heck are you doing with all this distilled water. I have a 27 gallon tote for cooling. It is black and does not allow any light in. Thoughts on life of the water? Can I add some type of algaecide or similar (like what is used in a whole house humidifier)?
Yes aquarium algaecide works.
The only distilled water I found at Walmart had “minerals added for taste,” which kind of missed the whole point of distilled water overall I think, but definitely for K40. Worth checking to make sure you didn’t get what I can only think to call “undistilled” water!
They sell it by the gallon jug for humidifiers without minerals.
You’ve got to be kidding me… I just checked. 24 gallons are the minerals added kind… What a waste.
This is what I purchase from Walmart. Steam distilled.
https://www.walmart.com/ip/Great-Value-Distilled-Water-1-Gallon/10315382
They only had six gallons of that one available so I bought the rest in that other one without realizing that it won’t work.
So, gotta buy more of the good stuff and find other uses for the “enhanced flavor” stuff?
Or return it? I mean, I don’t know how much of the minerals they add, but I wouldn’t risk my laser tube on it. I think I paid 89¢/gallon for proper distilled water at the grocery store.
I guess you could be mini-prepper and store it all to be prepared for a very short apocalypse?
24 gallons is a four day emergency supply for my family. Better be a short apocalypse! I haven’t been in a walmart since March. I have enough plants to use this on.
I have updated Cooling the K40 laser tube to mention the problem with distilled water with minerals added. Note that it has a recommendation for a specific algaecide, as well.
I found that home depot carries distilled water (the good stuff) in one gallon containers in a store near me for a good price. I will get it there. Thank you for the help!
At some point in time, it has got to become worthwhile to just have your own distiller, right? I don’t remember numbers, but I believe we were getting the PPM so low that the water would have counted as deionized, not just distilled.
It would be useful to measure the conductivity of this mineralized & distilled water to see where its conductivity sits on the spectrum of fluids we have tested.
Consider we have some sense of the levels of conductivity that don’t work but really never identified the conductivity level that is “acceptable”.
I found that there are a lot of different mineralized distilled waters out there, and I see no particular reason to think that they have similar conductivity. “Salt to taste” and all that…
The fact that we don’t know what the limits of acceptable conductivity are — only that it’s very clear that too high conductivity is bad — and the probability that it is different depending on the electrical characteristics of a machine, combined with how cheap it is to replace especially vs. the cost of tube and LPS, made me think that the easiest answer is “just don’t go there.”
All that said, I understand that you actually have the educational background and work experience here to do it right, and as a software guy who just dabbles here, I don’t. I just remember reading this and realizing that it is not as trivial as using a VMM to measure resistance…
I can’t remember whether you were using AgCl electrodes or what when you characterized conductivity, but it did seem to me like something where it was easy for someone like me to confidently come to the wrong conclusion from lack of knowledge.
Correct a VMM is not an accurate way to measure conductivity. I used a conductivity meter designed for this measurement.
My point was only that “someone” should measure it and add it to our data. I will if I find this type of water, I have not noticed it in on our walmart’s shelves.
Some day I will get an old tube and measure and characterize coolant conductivity effects systematically. For now the right approach is “don’t go there”.
FWIW, I tested the mineralized distilled water with a TDS meter. It came out to 10ppm. The regular distilled was 0-1ppm. My tap water was 400ppm.
Does your meter have a conductivity mode?
TDS and conductivity are related but not the same thing.
You can convert TDS to conductivity if you have the meters TDS to Conductivity conversion factor.
Note: I have been using a Com-100
Useful link: http://hmdigital.com/education-center/
Thanks, Don. My current meter does not. However, it wouldn’t be terrible to pick one up that does. I will look at the model that you use.
Here is where I got mine: https://amzn.to/2Xh5BGk
As an Amazon Affiliate, I earn from qualifying purchases.
