Hi,
I’ve got a part here and I’ve set the roof/floor layers and the wall thickness and infill. All good. But I need extra thickness around the screw holes to tap an M6 thread. I don’t want to increase the overall wall thickness. I’m using inventor to design the part and save to STL.
I tried putting an extra cylinder around the holes but looking at the layer slices, I can see the cylinder but it just seems to print as if it’s not there.
I use two techniques for holes I tap, or use self-tapping screws in.
One is positioning. Placing them so that my slicer treats the space around the hole as being below the ‘solid infill for small areas’ threshold and reinforces the mounting. Or near to other external walls so that the gap is filled.
The other is to use a hexagonal (or pentagonal) hole, with the Outer Diameter set to the clearance diameter of the screw.
This gives a good grip on the screw, without weakening the hole too much even when using the default wall size. I’ve used it several times in both PLA and PETG parts.
For instance; here is a detail from a case I designed:
