A few days ago I got my new Vigotec VG-L7 (BX20). But the software works not well. I have problem to import g-code and dxf-files. According to the description, it should be possible to use other software such as GRBL, Benbox, Elekscam. Apparently a new firmware is needed for this. Has anyone used other software on this engraver?
Hey mate, so after much struggling I have ended up BACK on the VigoWorks software.
LaserGRBL… LaserWEB… Candle and LightBurn all won’t run my VG-L7X. LaserGRBL will turn the laser on but the motors won’t move. They just like lock up and burn a hole to the core of the earth. I’ve been trying to re-flash my Controller with a new Grbl Firmware but nothing has synced and worked at all. Once I got my driver’s and COM Port situation cleared, the VigoWorks app is working great. I’ve got a 20W laser and it’s incredibly too strong to engrave, it’s strictly cutting haha
Here’s someone on the lightburn forum who successfully flashed stock grbl. @LightBurn suggests that the controller might have shipped with a hacked grbl intended to work only with the software they shipped.
HI, wood again - I also have the vigotec LX7 (without Wifi) and have written Vigotec VG-L7 BX20 image sizing/ printable area
to tell about switching to Grbl - worked fine, except use of fan (which is always on).
Either I was very lucky or nobody tried to ‘just upload’ GRBL by using the China-Software.
In the meantime i have been working with laserGRBL for a few weeks without any problems. At the moment I’m working on Lightburn (with GRBL) on the Vigotec VG-7. That seems to work fine too.
hy.
just burned my laser from cnc 3018*(it worked fine for 2 years), and ordered a vg-l7 no wifi.
Can you tell me how to change the firmware to make it work with lightburn?
