Hello there, anyone here using older VG-L7 with Lightburn to chime in how set it to work for newbies please?
Flash the fw, set 330x190mm area when adding device. But how with laser output regulation and weak light does it works out of box? And resolution, thought device is usual 300dpi but vigo sw have 15d per mm, so set the same in lightburn and import images as such to get best results? Thanks all
Start with the Common Grbl Setup
Then a good idea of how things are arranged at the Coordinate and Job Origin.
Good luck
