i thought it uses M4 instead of M3 now for on command using the dynamic laser mode available in grbl, worth trying that. For stopping the laser and pausing you might try to make a macro command that sends the appropriate G code. And live jogging requires you to enable it, then alt-click where you want to move the laser head to that point(might be ctrl-click, been a while)
@Ariel_Yahni_UniKpty
-thank you. I am running GRBL1.1f and today I have changed the machine profile to GenericGRBL and ToolOn=M4. However the problems remain, Laser off not working, no check size with laser.
I will study how to write a macro.
@CescoAiel
thank you, but the link seems broken: “Cannot use string offset as an array”-error. Would be good to publish the manual page for control viewport
@Stefan_Geisenheiner1 did you change the whole profile or just manually added the M4? Also is laser mode enabled in GRBL?
The reason I ask you to do this is to make shure you are running defaults and we can troubleshoot correctly.
understood, the whole profile was applied and GCODE-START includes M4 S0, which should enable laser TTL mode. I added ToolOn=M4 manually.
@Ariel_Yahni_UniKpty hmm, to make sure I uninstalled Laserweb and started clean (I hope, please confirm if settings should be gone). However the generic GRBL settings on my installation do not set gcodeToolOn value.
You can switch the laser on before clicking “Check Size” if you want to check the size with the laser switched on. Just make sure you configure “Tool Test Power” in settings/gcode.
