Using a Smoothieboard and think the web interface could be better ? We do too !
You can now upgrade your interface by installing files on your SD card.
Please follow the instructions here : http://smoothieware.org/install-web-interface
If you need any help, don’t hesitate to ask.
Arthur, when I try to open the zip file it says the file is invalid and won’t open? This will allow me to connect my printer via the Ethernet cable right? Can I still use Pronterface or slicer 3D?
Thanks.
Are you doing exactly what it’s saying here : http://smoothieware.org/install-web-interface ?
It works for me.
Did you watch the video ?
Also, this assumes you did setup network for your board : http://smoothieware.org/network
cprezzi
(Claudio Prezzi)
June 20, 2016, 7:33am
#4
Daniel: It seems your download is corrupted. I downloaded it too and was able to unzip without problems.
I had problems unzipping with the built in unzipper in Windows 10. I used WinRar instead, and it unzipped fine.
7Zip has been reported to work too, I added a link to it in the installation documentation.
