Hi arthurwolf
For some reason I cannot copy all from dmesg listing.
This is what I get when smoothieboard is connected.
lsusb:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
dmesg:
[ 0.369787] fuse init (API version 7.17)
[ 0.369966] msgmni has been set to 1435
[ 0.380780] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.384348] io scheduler noop registered
[ 0.384355] io scheduler deadline registered
[ 0.384399] io scheduler cfq registered (default)
[ 0.384688] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.384732] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.385002] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input0
[ 0.404493] ACPI: Lid Switch [LID]
[ 0.404644] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1
[ 0.404654] ACPI: Sleep Button [SLPB]
[ 0.404735] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.404740] ACPI: Power Button [PWRF]
[ 0.404889] ACPI: Fan [FAN0] (off)
[ 0.404948] ACPI: Fan [FAN1] (off)
[ 0.405017] Marking TSC unstable due to TSC halts in idle
[ 0.405029] ACPI: acpi_idle registered with cpuidle
[ 0.436273] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.436280] ACPI: Thermal Zone [THRM] (27 C)
[ 0.436392] ERST: Table is not found!
[ 0.436395] GHES: HEST is not enabled!
[ 0.436706] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.438968] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
[ 0.438979] serial 0000:00:1f.6: PCI INT B -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 0.439008] serial 0000:00:1f.6: PCI INT B disabled
[ 0.439268] Linux agpgart interface v0.103
[ 0.439354] agpgart-intel 0000:00:00.0: Intel 855GM Chipset
[ 0.439382] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable
[ 0.439620] agpgart-intel 0000:00:00.0: detected 16384K stolen memory
[ 0.444383] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[ 0.445723] isapnp: Scanning for PnP cards…
[ 0.452633] brd: module loaded
[ 0.453943] loop: module loaded
[ 0.454242] ata_piix 0000:00:1f.1: version 2.13
[ 0.454264] ata_piix 0000:00:1f.1: power state changed by ACPI to D0
[ 0.454270] ata_piix 0000:00:1f.1: power state changed by ACPI to D0
[ 0.454278] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[ 0.454293] ata_piix 0000:00:1f.1: PCI INT A -> Link[LNKC] -> GSI 6 (level, low) -> IRQ 6
[ 0.454354] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.547851] scsi0 : ata_piix
[ 0.548126] scsi1 : ata_piix
[ 0.549112] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1810 irq 14
[ 0.549118] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1818 irq 15
[ 0.549874] Fixed MDIO Bus: probed
[ 0.549909] tun: Universal TUN/TAP device driver, 1.6
[ 0.549912] tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.550022] PPP generic driver version 2.4.2
[ 0.550382] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.550423] ehci_hcd 0000:00:1d.7: PCI INT D -> Link[LNKH] -> GSI 10 (level, low) -> IRQ 10
[ 0.550451] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.550456] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.550521] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.550563] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.554460] ehci_hcd 0000:00:1d.7: cache line size of 32 is not supported
[ 0.560088] ehci_hcd 0000:00:1d.7: irq 10, io mem 0xe0100000
[ 0.572124] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.572458] hub 1-0:1.0: USB hub found
[ 0.572467] hub 1-0:1.0: 6 ports detected
[ 0.572613] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 0.572645] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.572710] uhci_hcd 0000:00:1d.0: PCI INT A -> Link[LNKA] -> GSI 6 (level, low) -> IRQ 6
[ 0.572728] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.572733] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.572820] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.572859] uhci_hcd 0000:00:1d.0: irq 6, io base 0x00001820
[ 0.573087] hub 2-0:1.0: USB hub found
[ 0.573093] hub 2-0:1.0: 2 ports detected
[ 0.573198] uhci_hcd 0000:00:1d.1: PCI INT B -> Link[LNKD] -> GSI 6 (level, low) -> IRQ 6
[ 0.573210] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.573214] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.573290] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.573316] uhci_hcd 0000:00:1d.1: irq 6, io base 0x00001840
[ 0.573531] hub 3-0:1.0: USB hub found
[ 0.573537] hub 3-0:1.0: 2 ports detected
[ 0.573632] uhci_hcd 0000:00:1d.2: PCI INT C -> Link[LNKC] -> GSI 6 (level, low) -> IRQ 6
[ 0.573643] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.573648] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.573711] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.573736] uhci_hcd 0000:00:1d.2: irq 6, io base 0x00001860
[ 0.573955] hub 4-0:1.0: USB hub found
[ 0.573962] hub 4-0:1.0: 2 ports detected
[ 0.574139] usbcore: registered new interface driver libusual
[ 0.574213] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:MOU2] at 0x60,0x64 irq 1,12
[ 0.576100] i8042: Detected active multiplexing controller, rev 1.1
[ 0.580954] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.580967] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.580972] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.580976] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.580980] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.581186] mousedev: PS/2 mouse device common for all mice
[ 0.581592] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 0.581615] rtc0: alarms up to one month, y3k, 242 bytes nvram
[ 0.581777] device-mapper: uevent: version 1.0.3
[ 0.581914] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 0.581981] EISA: Probing bus 0 at eisa.0
[ 0.581992] Cannot allocate resource for EISA slot 1
[ 0.581997] Cannot allocate resource for EISA slot 2
[ 0.582000] Cannot allocate resource for EISA slot 3
[ 0.582025] EISA: Detected 0 cards.
[ 0.582044] cpufreq-nforce2: No nForce2 chipset.
[ 0.582125] cpuidle: using governor ladder
[ 0.582211] cpuidle: using governor menu
[ 0.582214] EFI Variables Facility v0.08 2004-May-17
[ 0.582656] TCP cubic registered
[ 0.582873] NET: Registered protocol family 10
[ 0.583838] NET: Registered protocol family 17
[ 0.583872] Registering the dns_resolver key type
[ 0.583911] Using IPI No-Shortcut mode
[ 0.588384] PM: Hibernation image not present or could not be loaded.
[ 0.588420] registered taskstats version 1
[ 0.832751] ata2.01: NODEV after polling detection
[ 0.832942] ata1.00: ATA-6: HTS541040G9AT00, MB2OA60A, max UDMA/100
[ 0.832947] ata1.00: 78140160 sectors, multi 16: LBA48
[ 0.840866] ata2.00: ATAPI: UJDA760 DVD/CDRW, 1.00, max UDMA/33
[ 0.841249] ata1.00: configured for UDMA/100
[ 0.884841] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.885205] ata2.00: configured for UDMA/33
[ 0.935620] isapnp: No Plug & Play device found
[ 0.935952] scsi 0:0:0:0: Direct-Access ATA HTS541040G9AT00 MB2O PQ: 0 ANSI: 5
[ 0.936326] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.936598] sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 0.936673] sd 0:0:0:0: [sda] Write Protect is off
[ 0.936678] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.936710] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 0.973785] scsi 1:0:0:0: CD-ROM MATSHITA UJDA760 DVD/CDRW 1.00 PQ: 0 ANSI: 5
[ 0.975892] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 0.975899] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 0.976187] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 0.976409] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.037322] sda: sda1 sda2 < sda5 sda6 sda7 >
[ 1.038130] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.044341] hub 1-0:1.0: over-current condition on port 1
[ 1.222914] Freeing initrd memory: 13792k freed
[ 1.247675] Magic number: 0:990:538
[ 1.247740] tty ttyS18: hash matches
[ 1.247857] rtc_cmos 00:01: setting system clock to 2016-01-26 15:31:47 UTC (1453822307)
[ 1.247903] ACPI Exception: AE_NOT_FOUND, Evaluating _PSS (20110623/processor_perflib-318)
[ 1.247917] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.247919] EDD information not available.
[ 1.248193] Freeing unused kernel memory: 712k freed
[ 1.248764] Write protecting the kernel text: 5632k
[ 1.248826] Write protecting the kernel read-only data: 2324k
[ 1.252159] hub 1-0:1.0: over-current condition on port 2
[ 1.280203] udevd[86]: starting version 175
[ 1.460098] hub 2-0:1.0: over-current condition on port 1
[ 1.523369] b44 0000:02:02.0: PCI INT A -> Link[LNKD] -> GSI 6 (level, low) -> IRQ 6
[ 1.568161] ssb: Core 0 found: Fast Ethernet (cc 0x806, rev 0x04, vendor 0x4243)
[ 1.568171] ssb: Core 1 found: V90 (cc 0x807, rev 0x01, vendor 0x4243)
[ 1.568178] ssb: Core 2 found: PCI (cc 0x804, rev 0x02, vendor 0x4243)
[ 1.608352] ssb: Sonics Silicon Backplane found on PCI device 0000:02:02.0
[ 1.608389] b44: Broadcom 44xx/47xx 10/100 PCI ethernet driver version 2.0
[ 1.629396] b44 ssb0:0: eth0: Broadcom 44xx/47xx 10/100 PCI ethernet driver 00:c0:9f:5d:b9:27
[ 1.668067] hub 2-0:1.0: over-current condition on port 2
[ 1.981193] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 28.394863] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 28.455212] udevd[301]: starting version 175
[ 28.523111] lp: driver loaded but no devices found
[ 28.533070] Adding 750588k swap on /dev/sda7. Priority:-1 extents:1 across:750588k
[ 28.770971] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
[ 28.922264] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[ 28.946139] acpi device:05: registered as cooling_device3
[ 28.946386] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/LNXVIDEO:00/input/input4
[ 28.950157] ACPI: Video Device [GFX0] (multi-head: yes rom: yes post: no)
[ 29.099176] RPC: Registered named UNIX socket transport module.
[ 29.099183] RPC: Registered udp transport module.
[ 29.099186] RPC: Registered tcp transport module.
[ 29.099189] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 29.120263] FS-Cache: Loaded
[ 29.205134] FS-Cache: Netfs ‘nfs’ registered for caching
[ 29.336746] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[ 29.337807] Bluetooth: Core ver 2.16
[ 29.337856] NET: Registered protocol family 31
[ 29.337859] Bluetooth: HCI device and connection manager initialized
[ 29.337865] Bluetooth: HCI socket layer initialized
[ 29.337868] Bluetooth: L2CAP socket layer initialized
[ 29.337876] Bluetooth: SCO socket layer initialized
[ 29.357107] [drm] Initialized drm 1.1.0 20060810
[ 29.365389] ppdev: user-space parallel port driver
[ 29.443933] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 29.443939] Bluetooth: BNEP filters: protocol multicast
[ 29.449371] ACPI: SBS HC: EC = 0xecca5840, offset = 0x18, query_bit = 0x20
[ 29.658119] type=1400 audit(1453818735.907:2): apparmor=“STATUS” operation=“profile_load” name="/usr/lib/cups/backend/cups-pdf" pid=586 comm=“apparmor_parser”
[ 29.663403] type=1400 audit(1453818735.911:3): apparmor=“STATUS” operation=“profile_load” name="/usr/sbin/cupsd" pid=586 comm=“apparmor_parser”
[ 29.686837] intel_rng: FWH not detected
[ 29.691378] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 29.800339] init: portmap-wait (statd) main process (596) killed by TERM signal
[ 29.887741] init: statd-mounting main process (505) killed by TERM signal
[ 30.115542] yenta_cardbus 0000:02:06.0: CardBus bridge found [1025:0064]
[ 30.115561] yenta_cardbus 0000:02:06.0: Enabling burst memory read transactions
[ 30.115567] yenta_cardbus 0000:02:06.0: Using CSCINT to route CSC interrupts to PCI
[ 30.115571] yenta_cardbus 0000:02:06.0: Routing CardBus interrupts to PCI
[ 30.115577] yenta_cardbus 0000:02:06.0: TI: mfunc 0x01a21b22, devctl 0x64
[ 30.218047] i915 0000:00:02.0: PCI INT A -> Link[LNKA] -> GSI 6 (level, low) -> IRQ 6
[ 30.218057] i915 0000:00:02.0: setting latency timer to 64
[ 30.255054] type=1400 audit(1453818736.503:4): apparmor=“STATUS” operation=“profile_load” name="/sbin/dhclient" pid=673 comm=“apparmor_parser”
[ 30.255832] type=1400 audit(1453818736.503:5): apparmor=“STATUS” operation=“profile_load” name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=673 comm=“apparmor_parser”
[ 30.266264] ACPI: Deprecated procfs I/F for SBS is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[ 30.268290] ACPI: Smart Battery System [SBS0]: AC Adapter [AC0] (on-line)
[ 30.273694] type=1400 audit(1453818736.523:6): apparmor=“STATUS” operation=“profile_load” name="/usr/lib/connman/scripts/dhclient-script" pid=673 comm=“apparmor_parser”
[ 30.348710] yenta_cardbus 0000:02:06.0: ISA IRQ mask 0x08b8, PCI irq 10
[ 30.348718] yenta_cardbus 0000:02:06.0: Socket status: 30000006
[ 30.348724] pci_bus 0000:02: Raising subordinate bus# of parent bus (#02) from #02 to #06
[ 30.348739] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge window: [io 0x3000-0x3fff]
[ 30.348745] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3000-0x3fff: excluding 0x3000-0x30ff 0x3400-0x34ff
[ 30.412746] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 30.412751] [drm] Driver supports precise vblank timestamp query.
[ 30.414919]
[ 30.414930] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge window: [mem 0xe0200000-0xe05fffff]
[ 30.414937] pcmcia_socket pcmcia_socket0: cs: memory probe 0xe0200000-0xe05fffff: excluding 0xe0200000-0xe023ffff
[ 30.414954] yenta_cardbus 0000:02:06.0: pcmcia: parent PCI bridge window: [mem 0x34000000-0x39ffffff pref]
[ 30.414959] pcmcia_socket pcmcia_socket0: cs: memory probe 0x34000000-0x39ffffff: excluding 0x34000000-0x39ffffff
[ 30.428147] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 30.512424] fixme: max PWM is zero.
[ 31.103728] [drm] initialized overlay support
[ 31.111151] psmouse serio4: synaptics: Touchpad model: 1, fw: 5.9, id: 0x126eb1, caps: 0xa04713/0x4000/0x0
[ 31.190311] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input5
[ 31.289466] init: failsafe main process (744) killed by TERM signal
[ 31.812582] type=1400 audit(1453818738.063:7): apparmor=“STATUS” operation=“profile_load” name="/usr/share/gdm/guest-session/Xsession" pid=850 comm=“apparmor_parser”
[ 31.852116] type=1400 audit(1453818738.103:8): apparmor=“STATUS” operation=“profile_load” name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=851 comm=“apparmor_parser”
[ 31.863402] type=1400 audit(1453818738.111:9): apparmor=“STATUS” operation=“profile_replace” name="/sbin/dhclient" pid=857 comm=“apparmor_parser”
[ 31.874204] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.882381] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.885711] type=1400 audit(1453818738.135:10): apparmor=“STATUS” operation=“profile_replace” name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=857 comm=“apparmor_parser”
[ 31.886183] type=1400 audit(1453818738.135:11): apparmor=“STATUS” operation=“profile_replace” name="/usr/lib/connman/scripts/dhclient-script" pid=857 comm=“apparmor_parser”
[ 31.903751] fbcon: inteldrmfb (fb0) is primary device
[ 31.906734] Console: switching to colour frame buffer device 128x48
[ 31.906787] fb0: inteldrmfb frame buffer device
[ 31.906790] drm: registered panic notifier
[ 31.906865] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 31.906936] snd_intel8x0 0000:00:1f.5: PCI INT B -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 31.906982] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[ 32.160384] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: excluding 0x170-0x177 0x1c0-0x1cf 0x1f0-0x1f7 0x370-0x377
[ 32.161974] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: excluding 0x3f0-0x3f7 0x4d0-0x4d7
[ 32.162652] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 32.163213] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 32.163834] pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0fffff: excluding 0xc0000-0xc7fff 0xcc000-0xcffff 0xdc000-0xfffff
[ 32.163874] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
[ 32.163913] pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: clean.
[ 32.163950] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 32.272069] intel8x0_measure_ac97_clock: measured 53770 usecs (2591 samples)
[ 32.272076] intel8x0: clocking to 48000
[ 33.409772] init: gdm main process (998) killed by TERM signal
[ 34.208070] ACPI: Deprecated procfs I/F for SBS is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[ 34.208379] ACPI: Smart Battery System [SBS0]: Battery Slot [BAT0] (battery present)
[ 393.476058] usb 3-2: new full-speed USB device number 2 using uhci_hcd
[ 393.596053] usb 3-2: device descriptor read/64, error -71
[ 393.820060] usb 3-2: device descriptor read/64, error -71
[ 394.036053] usb 3-2: new full-speed USB device number 3 using uhci_hcd
[ 394.156043] usb 3-2: device descriptor read/64, error -71
[ 394.380045] usb 3-2: device descriptor read/64, error -71
[ 394.596045] usb 3-2: new full-speed USB device number 4 using uhci_hcd
[ 395.004038] usb 3-2: device not accepting address 4, error -71
[ 395.116051] usb 3-2: new full-speed USB device number 5 using uhci_hcd
[ 395.524046] usb 3-2: device not accepting address 5, error -71
[ 395.524066] hub 3-0:1.0: unable to enumerate USB device on port 2
[ 477.556261] usb 1-3: new high-speed USB device number 3 using ehci_hcd
[ 477.782620] Initializing USB Mass Storage driver…
[ 477.784618] scsi2 : usb-storage 1-3:1.0
[ 477.784784] usbcore: registered new interface driver usb-storage
[ 477.784788] USB Mass Storage support registered.
[ 477.817462] usbcore: registered new interface driver uas
[ 478.784951] scsi 2:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 478.790873] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 478.792545] sd 2:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 478.793444] sd 2:0:0:0: [sdb] Write Protect is off
[ 478.793452] sd 2:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 478.793923] sd 2:0:0:0: [sdb] No Caching mode page present
[ 478.793930] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 478.796507] sd 2:0:0:0: [sdb] No Caching mode page present
[ 478.796516] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 478.800788] sdb: unknown partition table
[ 478.803822] sd 2:0:0:0: [sdb] No Caching mode page present
[ 478.803832] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 478.803838] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 497.985826] usb 1-3: USB disconnect, device number 3
[ 497.996194] sd 2:0:0:0: [sdb] Unhandled error code
[ 497.996203] sd 2:0:0:0: [sdb] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 497.996210] sd 2:0:0:0: [sdb] CDB: Write(10): 2a 00 00 5d 3b 78 00 00 f0 00
[ 497.996224] end_request: I/O error, dev sdb, sector 6110072
[ 497.996233] quiet_error: 45 callbacks suppressed
[ 497.996237] Buffer I/O error on device sdb, logical block 6110072
[ 497.996240] lost page write due to I/O error on sdb
[ 497.996247] Buffer I/O error on device sdb, logical block 6110073
[ 497.996250] lost page write due to I/O error on sdb
[ 497.996253] Buffer I/O error on device sdb, logical block 6110074
[ 497.996256] lost page write due to I/O error on sdb
[ 497.996260] Buffer I/O error on device sdb, logical block 6110075
[ 497.996263] lost page write due to I/O error on sdb
[ 497.996266] Buffer I/O error on device sdb, logical block 6110076
[ 497.996269] lost page write due to I/O error on sdb
[ 497.996272] Buffer I/O error on device sdb, logical block 6110077
[ 497.996275] lost page write due to I/O error on sdb
[ 497.996279] Buffer I/O error on device sdb, logical block 6110078
[ 497.996282] lost page write due to I/O error on sdb
[ 497.996285] Buffer I/O error on device sdb, logical block 6110079
[ 497.996288] lost page write due to I/O error on sdb
[ 497.996302] Buffer I/O error on device sdb, logical block 6110080
[ 497.996305] lost page write due to I/O error on sdb
[ 497.996308] Buffer I/O error on device sdb, logical block 6110081
[ 497.996311] lost page write due to I/O error on sdb
[ 498.074376] VFS: busy inodes on changed media or resized disk sdb
[ 498.264589] init: ureadahead-other main process (2004) terminated with status 2
[ 607.368252] usb 1-4: new high-speed USB device number 4 using ehci_hcd
[ 607.506847] scsi3 : usb-storage 1-4:1.0
[ 608.504954] scsi 3:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 608.511230] sd 3:0:0:0: Attached scsi generic sg2 type 0
[ 608.511683] sd 3:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 608.513211] sd 3:0:0:0: [sdb] Write Protect is off
[ 608.513219] sd 3:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 608.513812] sd 3:0:0:0: [sdb] No Caching mode page present
[ 608.513819] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[ 608.517310] sd 3:0:0:0: [sdb] No Caching mode page present
[ 608.517319] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[ 608.521572] sdb: unknown partition table
[ 608.524793] sd 3:0:0:0: [sdb] No Caching mode page present
[ 608.524801] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[ 608.524807] sd 3:0:0:0: [sdb] Attached SCSI removable disk
[ 635.375533] usb 1-4: USB disconnect, device number 4
[ 648.280053] usb 3-2: new full-speed USB device number 6 using uhci_hcd
[ 648.400054] usb 3-2: device descriptor read/64, error -71
[ 648.624049] usb 3-2: device descriptor read/64, error -71
[ 648.840046] usb 3-2: new full-speed USB device number 7 using uhci_hcd
[ 648.960048] usb 3-2: device descriptor read/64, error -71
[ 649.184177] usb 3-2: device descriptor read/64, error -71
[ 649.400045] usb 3-2: new full-speed USB device number 8 using uhci_hcd
[ 649.808041] usb 3-2: device not accepting address 8, error -71
[ 649.920048] usb 3-2: new full-speed USB device number 9 using uhci_hcd
[ 650.328055] usb 3-2: device not accepting address 9, error -71
[ 650.328087] hub 3-0:1.0: unable to enumerate USB device on port 2
[ 677.740062] usb 3-1: new full-speed USB device number 10 using uhci_hcd
[ 677.860036] usb 3-1: device descriptor read/64, error -71
[ 678.084050] usb 3-1: device descriptor read/64, error -71
[ 678.300047] usb 3-1: new full-speed USB device number 11 using uhci_hcd
[ 678.420048] usb 3-1: device descriptor read/64, error -71
[ 678.644051] usb 3-1: device descriptor read/64, error -71
[ 678.860052] usb 3-1: new full-speed USB device number 12 using uhci_hcd
[ 679.268038] usb 3-1: device not accepting address 12, error -71
[ 679.380048] usb 3-1: new full-speed USB device number 13 using uhci_hcd
[ 679.788062] usb 3-1: device not accepting address 13, error -71
[ 679.788093] hub 3-0:1.0: unable to enumerate USB device on port 1
[ 822.952256] usb 1-4: new high-speed USB device number 7 using ehci_hcd
[ 823.090378] scsi4 : usb-storage 1-4:1.0
[ 824.088967] scsi 4:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 824.094985] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 824.095432] sd 4:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 824.096964] sd 4:0:0:0: [sdb] Write Protect is off
[ 824.096973] sd 4:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 824.097563] sd 4:0:0:0: [sdb] No Caching mode page present
[ 824.097570] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 824.101159] sd 4:0:0:0: [sdb] No Caching mode page present
[ 824.101168] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 824.105570] sdb: unknown partition table
[ 824.108917] sd 4:0:0:0: [sdb] No Caching mode page present
[ 824.108924] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[ 824.108930] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 1026.440982] usb 1-4: USB disconnect, device number 7
[ 1102.712254] usb 1-4: new high-speed USB device number 8 using ehci_hcd
[ 1102.848230] scsi5 : usb-storage 1-4:1.0
[ 1103.848958] scsi 5:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 1103.853841] sd 5:0:0:0: Attached scsi generic sg2 type 0
[ 1103.853928] sd 5:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 1103.854421] sd 5:0:0:0: [sdb] Write Protect is off
[ 1103.854428] sd 5:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 1103.854911] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1103.854917] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1103.858430] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1103.858439] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1103.861415] sdb: unknown partition table
[ 1103.863662] sd 5:0:0:0: [sdb] No Caching mode page present
[ 1103.863668] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[ 1103.863672] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[ 1196.004901] usb 1-4: USB disconnect, device number 8
[ 1325.872257] usb 1-4: new high-speed USB device number 9 using ehci_hcd
[ 1326.010393] scsi6 : usb-storage 1-4:1.0
[ 1327.008949] scsi 6:0:0:0: Direct-Access General UDisk 5.00 PQ: 0 ANSI: 2
[ 1327.014938] sd 6:0:0:0: Attached scsi generic sg2 type 0
[ 1327.016500] sd 6:0:0:0: [sdb] 262144000 512-byte logical blocks: (134 GB/125 GiB)
[ 1327.017031] sd 6:0:0:0: [sdb] Write Protect is off
[ 1327.017037] sd 6:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 1327.017537] sd 6:0:0:0: [sdb] No Caching mode page present
[ 1327.017544] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1327.019916] sd 6:0:0:0: [sdb] No Caching mode page present
[ 1327.019925] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1327.024438] sdb: unknown partition table
[ 1327.026773] sd 6:0:0:0: [sdb] No Caching mode page present
[ 1327.026781] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[ 1327.026787] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 1584.130397] usb 1-4: USB disconnect, device number 9
[ 1619.284056] usb 1-4: new high-speed USB device number 10 using ehci_hcd
[ 1619.424172] scsi7 : usb-storage 1-4:1.0
[ 1620.428593] scsi 7:0:0:0: Direct-Access CBM2080 Flash Disk 2.00 PQ: 0 ANSI: 2
[ 1620.431943] sd 7:0:0:0: [sdc] 254976 512-byte logical blocks: (130 MB/124 MiB)
[ 1620.432697] sd 7:0:0:0: [sdc] Write Protect is off
[ 1620.432703] sd 7:0:0:0: [sdc] Mode Sense: 0b 00 00 08
[ 1620.432951] sd 7:0:0:0: Attached scsi generic sg2 type 0
[ 1620.433194] sd 7:0:0:0: [sdc] No Caching mode page present
[ 1620.433200] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[ 1620.437333] sd 7:0:0:0: [sdc] No Caching mode page present
[ 1620.437343] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[ 1620.438448] sdc: sdc1
[ 1620.441186] sd 7:0:0:0: [sdc] No Caching mode page present
[ 1620.441194] sd 7:0:0:0: [sdc] Assuming drive cache: write through
[ 1620.441201] sd 7:0:0:0: [sdc] Attached SCSI removable disk
[ 1684.720186] usb 1-4: USB disconnect, device number 10
[ 1865.744063] usb 1-4: new high-speed USB device number 11 using ehci_hcd
[ 1865.884080] scsi8 : usb-storage 1-4:1.0
[ 1866.888567] scsi 8:0:0:0: Direct-Access CBM2080 Flash Disk 2.00 PQ: 0 ANSI: 2
[ 1866.891907] sd 8:0:0:0: [sdc] 254976 512-byte logical blocks: (130 MB/124 MiB)
[ 1866.892413] sd 8:0:0:0: [sdc] Write Protect is off
[ 1866.892420] sd 8:0:0:0: [sdc] Mode Sense: 0b 00 00 08
[ 1866.893208] sd 8:0:0:0: [sdc] No Caching mode page present
[ 1866.893216] sd 8:0:0:0: [sdc] Assuming drive cache: write through
[ 1866.895079] sd 8:0:0:0: Attached scsi generic sg2 type 0
[ 1866.896541] sd 8:0:0:0: [sdc] No Caching mode page present
[ 1866.896549] sd 8:0:0:0: [sdc] Assuming drive cache: write through
[ 1866.898180] sdc: sdc1
[ 1866.901162] sd 8:0:0:0: [sdc] No Caching mode page present
[ 1866.901170] sd 8:0:0:0: [sdc] Assuming drive cache: write through
[ 1866.901176] sd 8:0:0:0: [sdc] Attached SCSI removable disk
[ 1995.605305] usb 1-4: USB disconnect, device number 11
