updating Marlin RC4 to RC7… getting a maxtemp triggered system stopped problem … what should i look for since it seems like i have transfered the settings correctly
Check that you’ve selected the correct thermistors. If you’re not using a specific thermistor, comment if out.
In previous releases, you could specify say thermistor for your heatbed, and would not use it. Now if you specify it, then it will use it…
Just comment out the thermistors that don’t actually exist
MAXTEMP usually indicates a short in the thermistor lines.
