@donkjr The Eleksmaker is a Diode Laser, so no LPS there.
@enhydra If the [Laser Test] button works, then at least your firmware settings are ok. Did you start with the [Generic GRBL machine] profile in LaserWeb? (hit apply after selecting the dropdown)
You should also check the Gcode settings in LaserWeb:
[GCODE GENERATOR] should be default
[LASER INTENSITY] should be S
[PWM MIN S VALUE] should be 0
[PWM MAX S VALUE] should be 1000 (grbl default)
