File “/Users/douglaspearless/Documents/workspace/Smoothieware/gcc-arm-none-eabi/arm-none-eabi/share/gdb/python/gdb/init.py”, line 19, in <module>
Copyright (C) 2012 Free Software Foundation, Inc.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type “show copying”
and “show warranty” for details.
This GDB was configured as “host=x86_64-apple-darwin11.4.2 —target=arm-none-eabi”.
Reading symbols from /Users/douglaspearless/Documents/workspace/Smoothieware/LPC1768/main.elf…done.
Copying output to gdb.txt.
No stack.
I then tried a J-Link JTAG debugger, and I got it to work only once (up to the init() in main.cpp when it segfaulted and I have not been able to get it to work again. I followed NXP’s instructions to get GDB/J-Link working and I got the following log trace, it seems to show the the main.elf file is correctly flashed, but the gdb server disconnect shortly after that:
SEGGER J-Link GDB Server V4.98 LogFile
Logging started @ 2015-04-03 16:55
03-00000000-00-00000000-0023: -----GDB Server start settings-----
03-00000000-00-00000000-0023: GDBInit file: none
03-00000000-00-00000000-0023: GDB Server Listening port: 2331
03-00000000-00-00000000-0023: SWO raw output listening port: 2332
03-00000000-00-00000000-0023: Terminal I/O port: 2333
03-00000000-00-00000000-002D: Accept remote connection: localhost only
03-00000000-00-00000000-0021: Generate logfile: on
03-00000000-00-00000000-0021: Verify download: on
03-00000000-00-00000000-0021: Init regs on start: on
03-00000000-00-00000000-0022: Silent mode: off
03-00000000-00-00000000-0021: Single run mode: on
03-00000000-00-00000000-0023: Target connection timeout: 0 ms
03-00000000-00-00000000-0023: ------J-Link related settings------
03-00000000-00-00000000-0022: J-Link Host interface: USB
03-00000000-00-00000000-0023: J-Link script: none
03-00000000-00-00000000-0023: J-Link settings file: none
03-00000000-00-00000000-0023: ------Target related settings------
03-00000000-00-00000000-0026: Target device: LPC1769
03-00000000-00-00000000-0022: Target interface: SWD
03-00000000-00-00000000-0023: Target interface speed: 0kHz
03-00000000-00-00000000-0025: Target endian: little
03-00000000-00-00000000-0017: Connecting to J-Link...
02-00000000-00-00000029-0031: Firmware: J-Link V9 compiled Feb 20 2015 09:20:19
02-00000000-00-00000029-000F: Hardware: V9.20
02-00000000-00-00000282-0053: Feature(s): GDB, RDI, FlashBP, FlashDL, JFlash returns O.K. (0282ms, 0282ms total)
03-00000000-00-00000282-0014: J-Link is connected.
02-00000000-00-00000282-0065: T1AD1000 000:283 JLINK_ExecCommand("HideDeviceSelection=1", ...) returns 0x00 (0000ms, 0282ms total)
02-00000000-00-00000283-0060: T1AD1000 000:283 JLINK_ExecCommand("device = LPC1769", ...) returns 0x00 (0001ms, 0283ms total)
02-00000000-00-00000283-006B: T1AD1000 000:284 JLINK_ExecCommand("SetFlashRewriteBehavior = 1", ...) returns 0x00 (0000ms, 0283ms total)
02-00000000-00-00000283-0044: T1AD1000 000:284 JLINK_GetFirmwareString(...) (0000ms, 0283ms total)
03-00000000-00-00000283-0031: Firmware: J-Link V9 compiled Feb 20 2015 09:20:19
02-00000000-00-00000283-0053: T1AD1000 000:284 JLINK_GetHardwareVersion() returns 0x16760 (0000ms, 0283ms total)
03-00000000-00-00000283-000F: Hardware: V9.20
03-00000000-00-00000283-002E: Feature(s): GDB, RDI, FlashBP, FlashDL, JFlash
02-00000000-00-00000286-004C: T1AD1000 000:284 JLINK_GetHWStatus(...) returns 0x00 (0003ms, 0286ms total)
02-00000000-00-00000286-003F: T1AD1000 000:287 JLINK_EnableSoftBPs(ON) (0000ms, 0286ms total)
03-00000000-00-00000286-001A: Checking target voltage...
03-00000000-00-00000286-0016: Target voltage: 3.31 V
03-00000000-00-00000286-001D: Listening on TCP/IP port 2331
03-00000000-00-00000286-0017: Connecting to target...
02-00000000-00-00000286-0038: T1AD1000 000:287 JLINK_ClrError() (0000ms, 0286ms total)
02-00000000-00-00000286-004C: T1AD1000 000:287 JLINK_GetHWStatus(...) returns 0x00 (0000ms, 0286ms total)
02-00000000-00-00000287-0058: T1AD1000 000:287 JLINK_TIF_Select(JLINKARM_TIF_SWD) returns 0x00 (0001ms, 0287ms total)
02-00000000-00-00000313-01E6: T1AD1000 000:288 JLINK_SetSpeed(0) >0x108 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF>
02-00000000-00-00000336-01EA: -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_ReadMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE000EDFC) -- CPU_ReadMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE0001000) -- CPU_ReadMem(4 bytes @ 0xE000ED88) -- CPU_WriteMem(4 bytes @ 0xE000ED88) -- CPU_ReadMem(4 bytes @ 0xE000ED88) -- CPU_WriteMem(4 bytes @ 0xE000ED88)CoreSight components:ROMTbl 0 @ E00FF000 -- CPU_ReadMem(16 bytes @ 0xE00FF000) -- CPU_ReadMem(16 bytes @ 0xE000EFF0)
02-00000000-00-00000354-01EA: -- CPU_ReadMem(16 bytes @ 0xE000EFE0)ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 002BB000 SCS -- CPU_ReadMem(16 bytes @ 0xE0001FF0) -- CPU_ReadMem(16 bytes @ 0xE0001FE0)ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 002BB002 DWT -- CPU_ReadMem(16 bytes @ 0xE0002FF0) -- CPU_ReadMem(16 bytes @ 0xE0002FE0)ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB -- CPU_ReadMem(16 bytes @ 0xE0000FF0) -- CPU_ReadMem(16 bytes @ 0xE0000FE0)ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 002BB001 ITM
02-00000000-00-00000367-014E: -- CPU_ReadMem(16 bytes @ 0xE00FF010) -- CPU_ReadMem(16 bytes @ 0xE0040FF0) -- CPU_ReadMem(16 bytes @ 0xE0040FE0)ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 002BB923 TPIU-Lite -- CPU_ReadMem(16 bytes @ 0xE0041FF0) -- CPU_ReadMem(16 bytes @ 0xE0041FE0)ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 002BB924 ETM-M3 (0080ms, 0367ms total)
02-00000000-00-00000367-0047: T1AD1000 000:368 JLINK_GetSpeed() returns 0x7D0 (0000ms, 0367ms total)
02-00000000-00-00000367-0063: T1AD1000 000:368 JLINK_SetResetType(JLINKARM_RESET_TYPE_NORMAL) returns ??? (0000ms, 0367ms total)
02-00000000-00-00000367-003E: T1AD1000 000:368 JLINK_SetResetDelay(0) (0000ms, 0367ms total)
02-00000000-00-00000367-0058: T1AD1000 000:368 JLINK_SetEndian(ARM_ENDIAN_LITTLE) returns 0x00 (0000ms, 0367ms total)
02-00000000-00-00000386-01E4: T1AD1000 000:368 JLINK_Connect() >0x108 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF>
02-00000000-00-00000391-01EA: -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_ReadMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE000EDFC) -- CPU_ReadMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE0001000) -- CPU_ReadMem(4 bytes @ 0xE000ED88) -- CPU_WriteMem(4 bytes @ 0xE000ED88) -- CPU_ReadMem(4 bytes @ 0xE000ED88) -- CPU_WriteMem(4 bytes @ 0xE000ED88)CoreSight components:ROMTbl 0 @ E00FF000 -- CPU_ReadMem(16 bytes @ 0xE00FF000) -- CPU_ReadMem(16 bytes @ 0xE000EFF0)
02-00000000-00-00000395-01EA: -- CPU_ReadMem(16 bytes @ 0xE000EFE0)ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 002BB000 SCS -- CPU_ReadMem(16 bytes @ 0xE0001FF0) -- CPU_ReadMem(16 bytes @ 0xE0001FE0)ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 002BB002 DWT -- CPU_ReadMem(16 bytes @ 0xE0002FF0) -- CPU_ReadMem(16 bytes @ 0xE0002FE0)ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB -- CPU_ReadMem(16 bytes @ 0xE0000FF0) -- CPU_ReadMem(16 bytes @ 0xE0000FE0)ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 002BB001 ITM
02-00000000-00-00000397-015C: -- CPU_ReadMem(16 bytes @ 0xE00FF010) -- CPU_ReadMem(16 bytes @ 0xE0040FF0) -- CPU_ReadMem(16 bytes @ 0xE0040FE0)ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 002BB923 TPIU-Lite -- CPU_ReadMem(16 bytes @ 0xE0041FF0) -- CPU_ReadMem(16 bytes @ 0xE0041FE0)ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 002BB924 ETM-M3 returns 0x00 (0030ms, 0397ms total)
02-00000000-00-00000400-00A5: T1AD1000 000:398 JLINK_GetIdData(...) >0x0D TIF> >0x21 TIF> ScanLen=4 NumDevices=1 aId[0]=0x2BA01477 aIrRead[0]=0 aScanLen[0]=0 aScanRead[0]=0 (0003ms, 0400ms total)
02-00000000-00-00000400-004A: T1AD1000 000:401 JLINK_GetDeviceFamily() returns 3 (0000ms, 0400ms total)
02-00000000-00-00000403-0046: T1AD1000 000:401 JLINK_IsHalted() returns TRUE (0003ms, 0403ms total)
02-00000000-00-00000403-0046: T1AD1000 000:404 JLINK_IsHalted() returns TRUE (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R0, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R1, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R2, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R3, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R4, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R5, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R6, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R7, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R8, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0054: T1AD1000 000:404 JLINK_WriteReg(R9, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0055: T1AD1000 000:404 JLINK_WriteReg(R10, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0055: T1AD1000 000:404 JLINK_WriteReg(R11, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0055: T1AD1000 000:404 JLINK_WriteReg(R12, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-005A: T1AD1000 000:404 JLINK_WriteReg(R13 (SP), 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0055: T1AD1000 000:404 JLINK_WriteReg(R14, 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-005A: T1AD1000 000:404 JLINK_WriteReg(R15 (PC), 0x00000000) returns 0x00 (0000ms, 0400ms total)
02-00000000-00-00000403-0056: T1AD1000 000:404 JLINK_WriteReg(XPSR, 0x01000000) returns 0x00 (0000ms, 0400ms total)
03-00000000-00-00000403-0013: Connected to target
03-00000000-00-00000403-001D: Waiting for GDB connection...
03-00000000-00-00000589-0016: Connected to 127.0.0.1
00-0000000A-00-00000589-001B: +$qSupported:qRelocInsn+#9a
01-0000000A-00-00000589-0001: +
01-0000000A-00-00000589-0064: $PacketSize=4000;qXfer:memory-map:read-;QStartNoAckMode+;qXfer:threads:read+;qXfer:features:read+#ce
00-0000000A-00-00000590-0001: +
00-0000000A-00-00000590-0013: $QStartNoAckMode#b0
01-0000000A-00-00000590-0001: +
01-0000000A-00-00000590-0006: $OK#9a
00-0000000A-00-00000590-0007: $Hg0#df
00-0000000A-00-00000590-0028: $qXfer:features:read:target.xml:0,fff#7d
01-0000000A-00-00000590-07E5: $l<?xml version="1.0"?>
<!-- Copyright (C) 2008 Free Software Foundation, Inc.
Copying and distribution of this file, with or without modification,
are permitted in any medium without royalty provided the copyright
notice and this notice are preserved. -->
<!DOCTYPE feature SYSTEM “gdb-target.dtd”>
<target>
<architecture>arm</architecture>
<feature name=“org.gnu.gdb.arm.m-profile”>
<reg name=“r0” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r1” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r2” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r3” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r4” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r5” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r6” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r7” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r8” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r9” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r10” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r11” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“r12” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“sp” bitsize=“32” type=“data_ptr” group=“general”/>
<reg name=“lr” bitsize=“32” type=“uint32” group=“general”/>
<reg name=“pc” bitsize=“32” type=“code_ptr” group=“general”/>
<reg name=“xpsr” bitsize=“32” regnum=“25” type=“uint32” group=“general”/>
<reg name=“MSP” bitsize=“32” regnum=“26” type=“uint32” group=“general”/>
<reg name=“PSP” bitsize=“32” regnum=“27” type=“uint32” group=“general”/>
<reg name=“PRIMASK” bitsize=“32” regnum=“28” type=“uint32” group=“general”/>
<reg name=“BASEPRI” bitsize=“32” regnum=“29” type=“uint32” group=“general”/>
<reg name=“FAULTMASK” bitsize=“32” regnum=“30” type=“uint32” group=“general”/>
<reg name=“CONTROL” bitsize=“32” regnum=“31” type=“uint32” group=“general”/>
</feature>
</target>
#3d
00-0000000A-00-00000591-0005: $?#3f
01-0000000A-00-00000591-0007: $S05#b8
00-0000000A-00-00000591-0008: $Hc-1#09
01-0000000A-00-00000591-0006: $OK#9a
00-0000000A-00-00000591-0006: $qC#b4
01-0000000A-00-00000591-0004: $#00
00-0000000A-00-00000591-000D: $qAttached#8f
00-0000000A-00-00000592-0005: $g#67
03-00000000-00-00000592-0015: Reading all registers
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R1) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R4) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004D: T5607000 000:593 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004E: T5607000 000:593 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004E: T5607000 000:593 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004E: T5607000 000:593 JLINK_ReadReg(R12) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-0053: T5607000 000:593 JLINK_ReadReg(R13 (SP)) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004E: T5607000 000:593 JLINK_ReadReg(R14) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-0053: T5607000 000:593 JLINK_ReadReg(R15 (PC)) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004F: T5607000 000:593 JLINK_ReadReg(XPSR) returns 0x01000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004E: T5607000 000:593 JLINK_ReadReg(MSP) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-004E: T5607000 000:593 JLINK_ReadReg(PSP) returns 0xFCD24288 (0000ms, 0400ms total)
02-00000000-00-00000592-0052: T5607000 000:593 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-0052: T5607000 000:593 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000592-0054: T5607000 000:593 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 0400ms total)
02-00000000-00-00000593-0052: T5607000 000:593 JLINK_ReadReg(CONTROL) returns 0x00000000 (0001ms, 0401ms total)
01-0000000A-00-00000593-00BC: $0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001000000008842d2fc00000000000000000000000000000000#36
00-0000000A-00-00000593-0008: $m0,4#fd
02-00000000-00-00000594-011A: T5607000 000:594 JLINK_ReadMem (0x00000000, 0x0004 Bytes, …) – CPU_ReadMem(4 bytes @ 0x400FC040) – CPU_ReadMem(64 bytes @ 0x00000000) – Updating C cache (64 bytes @ 0x00000000) – Read from C cache (4 bytes @ 0x00000000) - Data: E0 7F 00 10 returns 0x00 (0001ms, 0402ms total)
03-00000000-00-00000594-0035: Read 4 bytes @ address 0x00000000 (Data = 0x10007FE0)
01-0000000A-00-00000594-000C: $e07f0010#f3
00-0000000A-00-00000595-000C: $qTStatus#49
01-0000000A-00-00000595-0004: $#00
00-0000000A-00-00000648-001E: $qRcmd,73706565642031303030#23
02-00000000-00-00000648-003C: T5607000 000:649 JLINK_SetSpeed(1000) (0000ms, 0402ms total)
02-00000000-00-00000648-0047: T5607000 000:649 JLINK_GetSpeed() returns 0x3E8 (0000ms, 0402ms total)
01-0000000A-00-00000648-0054: $54617267657420696e746572666163652073706565642073657420746f2031303030206b487a0D0A#1e
03-00000000-00-00000648-0026: Target interface speed set to 1000 kHz
00-0000000A-00-00000649-0014: $qRcmd,636c726270#5d
01-0000000A-00-00000649-0006: $OK#9a
00-0000000A-00-00000650-0014: $qRcmd,7265736574#37
02-00000000-00-00000650-0041: T5607000 000:651 JLINK_ResetPullsRESET(ON) (0000ms, 0402ms total)
02-00000000-00-00000674-01DA: T5607000 000:651 JLINK_Reset() – CPU_WriteMem(4 bytes @ 0xE000EDF0) – CPU_WriteMem(4 bytes @ 0xE000EDFC) >0x35 TIF> – CPU_WriteMem(4 bytes @ 0xE000ED0C) – CPU_ReadMem(4 bytes @ 0xE000EDF0) – CPU_ReadMem(4 bytes @ 0xE000EDF0) – CPU_WriteMem(4 bytes @ 0xE000EDF0) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU is running – CPU_ReadMem(4 bytes @ 0xE000EDF0) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE000EDFC)
02-00000000-00-00000795-01E8: – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE0001050) – CPU_WriteMem(4 bytes @ 0xE0001054) – CPU_WriteMem(4 bytes @ 0xE0001058) – CPU_ReadMem(4 bytes @ 0xE0001000) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE0001058) – CPU_ReadMem(4 bytes @ 0x00000004) – CPU_ReadMem(4 bytes @ 0xE0002000) – CPU_ReadMem(4 bytes @ 0xE0002008) – CPU_ReadMem(4 bytes @ 0xE000200C) – CPU_ReadMem(4 bytes @ 0xE0002010)
02-00000000-00-00000909-01E9: – CPU_ReadMem(4 bytes @ 0xE0002014) – CPU_ReadMem(4 bytes @ 0xE0002018) – CPU_ReadMem(4 bytes @ 0xE000201C) – CPU_WriteMem(4 bytes @ 0xE0002000) – CPU_WriteMem(4 bytes @ 0xE0002008) – CPU_WriteMem(4 bytes @ 0xE000200C) – CPU_WriteMem(4 bytes @ 0xE0002010) – CPU_WriteMem(4 bytes @ 0xE0002014) – CPU_WriteMem(4 bytes @ 0xE0002018) – CPU_WriteMem(4 bytes @ 0xE000201C) – CPU_ReadMem(4 bytes @ 0xE0001000) – CPU_ReadMem(4 bytes @ 0x400FC040) – CPU_WriteMem(4 bytes @ 0xE0002000)
02-00000000-00-00000915-016B: – CPU_WriteMem(4 bytes @ 0xE0002008) – CPU_WriteMem(4 bytes @ 0xE000200C) – CPU_WriteMem(4 bytes @ 0xE0002010) – CPU_WriteMem(4 bytes @ 0xE0002014) – CPU_WriteMem(4 bytes @ 0xE0002018) – CPU_WriteMem(4 bytes @ 0xE000201C) – CPU_WriteMem(4 bytes @ 0xE0002000) – CPU_ReadMem(4 bytes @ 0xE000EDFC) – CPU_ReadMem(4 bytes @ 0xE0001000) (0265ms, 0667ms total)
01-0000000A-00-00000915-0028: $526573657474696e67207461726765740D0A#b9
03-00000000-00-00000915-0010: Resetting target
00-0000000A-00-00000915-0012: $qRcmd,68616c74#fc
03-00000000-00-00000915-0015: Halting target CPU…
02-00000000-00-00000915-0042: T5607000 000:916 JLINK_Halt() returns 0x00 (0000ms, 0667ms total)
02-00000000-00-00000915-0046: T5607000 000:916 JLINK_IsHalted() returns TRUE (0000ms, 0667ms total)
02-00000000-00-00000915-0053: T5607000 000:916 JLINK_ReadReg(R15 (PC)) returns 0x000000CC (0000ms, 0667ms total)
03-00000000-00-00000915-0022: …Target halted (PC = 0x000000CC)
01-0000000A-00-00000915-0006: $OK#9a
00-0000000A-00-00000916-0012: $qRcmd,72656773#ce
02-00000000-00-00000916-0052: T5607000 000:917 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-0052: T5607000 000:917 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-0054: T5607000 000:917 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-0052: T5607000 000:917 JLINK_ReadReg(CONTROL) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-004F: T5607000 000:917 JLINK_ReadReg(CFBP) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-004F: T5607000 000:917 JLINK_ReadReg(IPSR) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-004F: T5607000 000:917 JLINK_ReadReg(EPSR) returns 0x01000000 (0000ms, 0667ms total)
02-00000000-00-00000916-004F: T5607000 000:917 JLINK_ReadReg(APSR) returns 0x60000000 (0000ms, 0667ms total)
02-00000000-00-00000916-004F: T5607000 000:917 JLINK_ReadReg(XPSR) returns 0x61000000 (0000ms, 0667ms total)
02-00000000-00-00000916-0053: T5607000 000:917 JLINK_ReadReg(R15 (PC)) returns 0x000000CC (0000ms, 0667ms total)
02-00000000-00-00000916-004E: T5607000 000:917 JLINK_ReadReg(R14) returns 0x1FFF0D5F (0000ms, 0667ms total)
02-00000000-00-00000916-004E: T5607000 000:917 JLINK_ReadReg(PSP) returns 0xFCD24288 (0000ms, 0667ms total)
02-00000000-00-00000916-004E: T5607000 000:917 JLINK_ReadReg(MSP) returns 0x10007FE0 (0000ms, 0667ms total)
02-00000000-00-00000916-0053: T5607000 000:917 JLINK_ReadReg(R13 (SP)) returns 0x10007FE0 (0000ms, 0667ms total)
02-00000000-00-00000916-004E: T5607000 000:917 JLINK_ReadReg(R12) returns 0x100005B8 (0000ms, 0667ms total)
02-00000000-00-00000916-004E: T5607000 000:917 JLINK_ReadReg(R11) returns 0x39726F2D (0000ms, 0667ms total)
02-00000000-00-00000916-004E: T5607000 000:917 JLINK_ReadReg(R10) returns 0xB60A1D4D (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R9) returns 0x0EDD6A83 (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R8) returns 0xBFFEB3B6 (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R6) returns 0x12345678 (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R5) returns 0x3456ABCD (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R4) returns 0x3456ABCD (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R1) returns 0x000000CD (0000ms, 0667ms total)
02-00000000-00-00000916-004D: T5607000 000:917 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 0667ms total)
01-0000000A-00-00000916-0322: $5230203d2030303030303030302c205231203d2030303030303043442c205232203d2030303030303030302c205233203d2030303030303030300a5234203d2033343536414243442c205235203d2033343536414243442c205236203d2031323334353637382c205237203d2030303030303030300a5238203d2042464645423342362c205239203d2030454444364138332c205231303d2042363041314434442c205231313d2033393732364632440a5231323d2031303030303542382c205231333d2031303030374645302c204d53503d2031303030374645302c205053503d2046434432343238380a523134284c5229203d2031464646304435462c2052313528504329203d2030303030303043430a585053522036313030303030302c20415053522036303030303030302c20455053522030313030303030302c20495053522030303030303030300a434642502030303030303030302c20434f4e54524f4c2030302c204641554c544d41534b2030302c20424153455052492030302c205052494d41534b2030300D0A#27
03-00000000-00-00000916-003A: R0 = 00000000, R1 = 000000CD, R2 = 00000000, R3 = 00000000
03-00000000-00-00000916-003A: R4 = 3456ABCD, R5 = 3456ABCD, R6 = 12345678, R7 = 00000000
03-00000000-00-00000916-003A: R8 = BFFEB3B6, R9 = 0EDD6A83, R10= B60A1D4D, R11= 39726F2D
03-00000000-00-00000916-003A: R12= 100005B8, R13= 10007FE0, MSP= 10007FE0, PSP= FCD24288
03-00000000-00-00000917-0026: R14(LR) = 1FFF0D5F, R15(PC) = 000000CC
03-00000000-00-00000917-003A: XPSR 61000000, APSR 60000000, EPSR 01000000, IPSR 00000000
03-00000000-00-00000917-003F: CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00
00-0000000A-00-00000917-0005: $g#67
03-00000000-00-00000917-0015: Reading all registers
02-00000000-00-00000917-004D: T5607000 000:918 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000917-004D: T5607000 000:918 JLINK_ReadReg(R1) returns 0x000000CD (0000ms, 0667ms total)
02-00000000-00-00000917-004D: T5607000 000:918 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000918-004D: T5607000 000:919 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000918-004D: T5607000 000:919 JLINK_ReadReg(R4) returns 0x3456ABCD (0000ms, 0667ms total)
02-00000000-00-00000918-004D: T5607000 000:919 JLINK_ReadReg(R5) returns 0x3456ABCD (0000ms, 0667ms total)
02-00000000-00-00000918-004D: T5607000 000:919 JLINK_ReadReg(R6) returns 0x12345678 (0000ms, 0667ms total)
02-00000000-00-00000918-004D: T5607000 000:919 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000918-004D: T5607000 000:919 JLINK_ReadReg(R8) returns 0xBFFEB3B6 (0000ms, 0667ms total)
02-00000000-00-00000918-004D: T5607000 000:919 JLINK_ReadReg(R9) returns 0x0EDD6A83 (0000ms, 0667ms total)
02-00000000-00-00000918-004E: T5607000 000:919 JLINK_ReadReg(R10) returns 0xB60A1D4D (0000ms, 0667ms total)
02-00000000-00-00000918-004E: T5607000 000:919 JLINK_ReadReg(R11) returns 0x39726F2D (0000ms, 0667ms total)
02-00000000-00-00000918-004E: T5607000 000:919 JLINK_ReadReg(R12) returns 0x100005B8 (0000ms, 0667ms total)
02-00000000-00-00000918-0053: T5607000 000:919 JLINK_ReadReg(R13 (SP)) returns 0x10007FE0 (0000ms, 0667ms total)
02-00000000-00-00000918-004E: T5607000 000:919 JLINK_ReadReg(R14) returns 0x1FFF0D5F (0000ms, 0667ms total)
02-00000000-00-00000918-0053: T5607000 000:919 JLINK_ReadReg(R15 (PC)) returns 0x000000CC (0000ms, 0667ms total)
02-00000000-00-00000918-004F: T5607000 000:919 JLINK_ReadReg(XPSR) returns 0x61000000 (0000ms, 0667ms total)
02-00000000-00-00000918-004E: T5607000 000:919 JLINK_ReadReg(MSP) returns 0x10007FE0 (0000ms, 0667ms total)
02-00000000-00-00000918-004E: T5607000 000:919 JLINK_ReadReg(PSP) returns 0xFCD24288 (0000ms, 0667ms total)
02-00000000-00-00000918-0052: T5607000 000:919 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000918-0052: T5607000 000:919 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000918-0054: T5607000 000:919 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 0667ms total)
02-00000000-00-00000918-0052: T5607000 000:919 JLINK_ReadReg(CONTROL) returns 0x00000000 (0000ms, 0667ms total)
01-0000000A-00-00000918-00BC: $00000000cd0000000000000000000000cdab5634cdab56347856341200000000b6b3febf836add0e4d1d0ab62d6f7239b8050010e07f00105f0dff1fcc00000000000061e07f00108842d2fc00000000000000000000000000000000#99
00-0000000A-00-00000918-001E: $qRcmd,7370656564206175746f#70
02-00000000-00-00000918-003B: T5607000 000:919 JLINK_SetMaxSpeed() (0000ms, 0667ms total)
02-00000000-00-00000918-0047: T5607000 000:919 JLINK_GetSpeed() returns 0x7D0 (0000ms, 0667ms total)
01-0000000A-00-00000918-0062: $53656c656374206175746f2074617267657420696e74657266616365207370656564202832303030206b487a290D0A#34
03-00000000-00-00000918-002D: Select auto target interface speed (2000 kHz)
00-0000000A-00-00000919-0030: $qRcmd,666c61736820627265616b706f696e74732031#ac
02-00000000-00-00000919-005E: T5607000 000:920 JLINK_ExecCommand(“EnableFlashBPs”, …) returns 0x00 (0000ms, 0667ms total)
01-0000000A-00-00000919-003A: $466c61736820627265616b706f696e747320656e61626c65640D0A#4b
03-00000000-00-00000919-0019: Flash breakpoints enabled
00-0000000A-00-00000919-002E: $qRcmd,73656d69686f7374696e6720656e61626c65#92
02-00000000-00-00000919-0069: T5607000 000:920 JLINK_SetBPEx(Addr = 0x00000008, Type = 0x01) returns 0x00000001 (0000ms, 0667ms total)
01-0000000A-00-00000919-0058: $53656d692d686f7374696e6720656e61626c65642028566563746f7241646472203d2030783038290D0A#d5
03-00000000-00-00000919-0028: Semi-hosting enabled (VectorAddr = 0x08)
00-0000000A-00-00000919-0036: $qRcmd,73656d69686f7374696e6720494f436c69656e742033#68
01-0000000A-00-00000919-0060: $53656d69686f7374696e6720492f4f2073657420746f2054454c4e455420616e642047444220436c69656e740D0A#04
03-00000000-00-00000920-002C: Semihosting I/O set to TELNET and GDB Client
00-0000000A-00-00000920-0042: $qRcmd,53574f2044697361626c655461726765742030784646464646464646#07
02-00000000-00-00000920-002A: T5607000 000:921 JLINK_SWO_DisableTarget()
02-00000000-00-00000920-009D: JLINK_ReadMemU32(0xE0000E00, 0x0001 Items, …) – CPU_ReadMem(4 bytes @ 0xE0000E00) - Data: 01 00 00 00 returns 0x01 (0000ms, 0000ms total)
02-00000000-00-00000921-005B: JLINK_WriteU32(0xE0000E00, 0x00000000) returns 0x00 (0000ms, 0001ms total)
02-00000000-00-00000921-005B: JLINK_WriteU32(0xE0000E80, 0x00000000) returns 0x00 (0000ms, 0001ms total)
02-00000000-00-00000921-0033: returns 0x00 (0001ms, 0668ms total)
01-0000000A-00-00000921-003A: $53574f2064697361626c65642073756363657366756c6c792e0D0A#25
03-00000000-00-00000921-0019: SWO disabled succesfully.
00-0000000A-00-00000921-003E: $qRcmd,53574f20456e61626c6554617267657420302030203078312030#2d
02-00000000-00-00000927-01F7: T5607000 000:922 JLINK_MeasureCPUSpeed(RAMAddr = 0xFFFFFFFF) – CPU_ReadMem(16 bytes @ 0x10000000) – CPU_ReadMem(64 bytes @ 0x10000000) – Updating C cache (64 bytes @ 0x10000000) – Read from C cache (6 bytes @ 0x10000000) – CPU_WriteMem(16 bytes @ 0x10000000) – CPU_WriteMem(6 bytes @ 0x10000000) – CPU_ReadMem(64 bytes @ 0x10000000) – Updating C cache (64 bytes @ 0x10000000) – Read from C cache (6 bytes @ 0x10000000) – CPU_WriteMem(4 bytes @ 0xE0000E00) – CPU_WriteMem(4 bytes @ 0xE0000E80)
02-00000000-00-00000963-01EE: – CPU_WriteMem(4 bytes @ 0xE0002008) – CPU_WriteMem(4 bytes @ 0xE000200C) – CPU_WriteMem(4 bytes @ 0xE0002010) – CPU_WriteMem(4 bytes @ 0xE0002014) – CPU_WriteMem(4 bytes @ 0xE0002018) – CPU_WriteMem(4 bytes @ 0xE000201C) – CPU_WriteMem(4 bytes @ 0xE0002008) – CPU_WriteMem(4 bytes @ 0xE000200C) – CPU_WriteMem(4 bytes @ 0xE0002010) – CPU_WriteMem(4 bytes @ 0xE0002014) – CPU_WriteMem(4 bytes @ 0xE0002018) – CPU_WriteMem(4 bytes @ 0xE000201C) – CPU_WriteMem(6 bytes @ 0x10000000)
02-00000000-00-00000963-0042: – ClockFreq: 4063950 Hz returns 0x3E02CE (0042ms, 0710ms total)
02-00000000-00-00000963-0068: T5607000 000:964 JLINK_SWO_GetCompatibleSpeeds(CPUSpeed = 4063950, MaxSWOSpeed = 0, …, NumEntries = 1)
02-00000000-00-00000964-006C: JLINK_SWO_Control(JLINKARM_SWO_CMD_GET_SPEED_INFO, …) returns 0x00 (0001ms, 0001ms total)
02-00000000-00-00000964-0033: returns 0x01 (0001ms, 0711ms total)
02-00000000-00-00000964-0059: T5607000 000:965 JLINK_SWO_EnableTarget(CPUSpeed = 4063950, SWOSpeed = 4000000, Mode = 0)
02-00000000-00-00000967-006C: JLINK_SWO_Control(JLINKARM_SWO_CMD_GET_SPEED_INFO, …) returns 0x00 (0003ms, 0003ms total)
02-00000000-00-00000967-009D: JLINK_ReadMemU32(0xE000EDFC, 0x0001 Items, …) – CPU_ReadMem(4 bytes @ 0xE000EDFC) - Data: 00 00 00 01 returns 0x01 (0000ms, 0003ms total)
02-00000000-00-00000968-0081: JLINK_WriteU32(0xE0000FB0, 0xC5ACCE55) – CPU_WriteMem(4 bytes @ 0xE0000FB0) returns 0x00 (0001ms, 0004ms total)
02-00000000-00-00000968-0078: JLINK_ReadMemU32(0xE0000E00, 0x0001 Items, …) - Data: 00 00 00 00 returns 0x01 (0000ms, 0004ms total)
02-00000000-00-00000968-0081: JLINK_WriteU32(0xE0000E00, 0x00000000) – CPU_WriteMem(4 bytes @ 0xE0000E00) returns 0x00 (0000ms, 0004ms total)
02-00000000-00-00000969-0081: JLINK_WriteU32(0xE0000E80, 0x00000000) – CPU_WriteMem(4 bytes @ 0xE0000E80) returns 0x00 (0000ms, 0005ms total)
02-00000000-00-00000970-0024: – UART – 4000000bps
02-00000000-00-00000970-0081: JLINK_WriteU32(0xE00400F0, 0x00000002) – CPU_WriteMem(4 bytes @ 0xE00400F0) returns 0x00 (0000ms, 0005ms total)
02-00000000-00-00000971-0081: JLINK_WriteU32(0xE0040010, 0x00000000) – CPU_WriteMem(4 bytes @ 0xE0040010) returns 0x00 (0001ms, 0006ms total)
02-00000000-00-00000971-0081: JLINK_WriteU32(0xE0000E40, 0x00000000) – CPU_WriteMem(4 bytes @ 0xE0000E40) returns 0x00 (0000ms, 0006ms total)
02-00000000-00-00000972-0058: – CPU_ReadMem(4 bytes @ 0xE0001000) – CPU_ReadMem(4 bytes @ 0xE0001000)
02-00000000-00-00000973-0081: JLINK_WriteU32(0xE0040304, 0x00000100) – CPU_WriteMem(4 bytes @ 0xE0040304) returns 0x00 (0001ms, 0008ms total)
02-00000000-00-00000974-0081: JLINK_WriteU32(0xE0000E80, 0x0001000D) – CPU_WriteMem(4 bytes @ 0xE0000E80) returns 0x00 (0001ms, 0009ms total)
02-00000000-00-00000974-0081: JLINK_WriteU32(0xE0000E00, 0x00000001) – CPU_WriteMem(4 bytes @ 0xE0000E00) returns 0x00 (0000ms, 0009ms total)
02-00000000-00-00000974-0033: returns 0x00 (0010ms, 0721ms total)
01-0000000A-00-00000974-0038: $53574f20656e61626c65642073756363657366756c6c792e0D0A#e8
03-00000000-00-00000974-0018: SWO enabled succesfully.
00-0000000A-00-00000975-0024: $qRcmd,696e7465726661636520737764#b7
02-00000000-00-00000977-0058: T5607000 000:978 JLINK_TIF_Select(JLINKARM_TIF_SWD) returns 0x00 (0000ms, 0721ms total)
01-0000000A-00-00000977-0044: $53656c656374205357442061732074617267657420696e746572666163650D0A#93
03-00000000-00-00000977-001E: Select SWD as target interface
00-0000000A-00-00000977-0036: $qRcmd,666c61736820646576696365203d204c504331373639#af
02-00000000-00-00000981-0096: T1D87000 000:978 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000)JLINK_ExecCommand(“Device = LPC1769”, …) returns 0x00 (0001ms, 0722ms total)
01-0000000A-00-00000981-003A: $53656c656374696e67206465766963653a204c5043313736390D0A#ea
02-00000000-00-00000981-0045: T1D87000 000:982 - Data: NumBytesRead = 0x00 (0000ms, 0722ms total)
03-00000000-00-00000981-0019: Selecting device: LPC1769
02-00000000-00-00000981-0064: T1D87000 000:982 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 0722ms total)
00-0000000A-00-00000981-002E: $qRcmd,666c61736820646f776e6c6f6164203d2031#9d
02-00000000-00-00000981-005D: T5607000 000:982 JLINK_ExecCommand(“EnableFlashDL”, …) returns 0x00 (0000ms, 0722ms total)
01-0000000A-00-00000981-0034: $466c61736820646f776e6c6f616420656e61626c65640D0A#43
03-00000000-00-00000981-0016: Flash download enabled
00-0000000A-00-00000982-0034: $qRcmd,666c61736820627265616b706f696e7473203d2031#a5
02-00000000-00-00000982-005E: T5607000 000:983 JLINK_ExecCommand(“EnableFlashBPs”, …) returns 0x00 (0000ms, 0722ms total)
01-0000000A-00-00000982-003A: $466c61736820627265616b706f696e747320656e61626c65640D0A#4b
03-00000000-00-00000982-0019: Flash breakpoints enabled
00-0000000A-00-00000982-001E: $qRcmd,7370656564206175746f#70
02-00000000-00-00000982-003B: T5607000 000:983 JLINK_SetMaxSpeed() (0000ms, 0722ms total)
02-00000000-00-00000982-0047: T5607000 000:983 JLINK_GetSpeed() returns 0x7D0 (0000ms, 0722ms total)
01-0000000A-00-00000982-0062: $53656c656374206175746f2074617267657420696e74657266616365207370656564202832303030206b487a290D0A#34
03-00000000-00-00000982-002D: Select auto target interface speed (2000 kHz)
00-0000000A-00-00000982-0014: $qRcmd,636c726270#5d
01-0000000A-00-00000982-0006: $OK#9a
00-0000000A-00-00000983-0018: $qRcmd,72657365742030#fc
02-00000000-00-00000983-0063: T5607000 000:984 JLINK_SetResetType(JLINKARM_RESET_TYPE_NORMAL) returns ??? (0000ms, 0722ms total)
02-00000000-00-00000983-0041: T5607000 000:984 JLINK_ResetPullsRESET(ON) (0000ms, 0722ms total)
02-00000000-00-00001005-01DA: T5607000 000:984 JLINK_Reset() – CPU_WriteMem(4 bytes @ 0xE000EDF0) – CPU_WriteMem(4 bytes @ 0xE000EDFC) >0x35 TIF> – CPU_WriteMem(4 bytes @ 0xE000ED0C) – CPU_ReadMem(4 bytes @ 0xE000EDF0) – CPU_ReadMem(4 bytes @ 0xE000EDF0) – CPU_WriteMem(4 bytes @ 0xE000EDF0) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU is running – CPU_ReadMem(4 bytes @ 0xE000EDF0) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE000EDFC)
02-00000000-00-00001011-01ED: – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE0001050) – CPU_WriteMem(4 bytes @ 0xE0001054) – CPU_WriteMem(4 bytes @ 0xE0001058) – CPU_ReadMem(4 bytes @ 0x400FC040) – CPU_WriteMem(4 bytes @ 0xE0002000) – CPU_WriteMem(4 bytes @ 0xE0002008) – CPU_WriteMem(4 bytes @ 0xE000200C) – CPU_WriteMem(4 bytes @ 0xE0002010) – CPU_WriteMem(4 bytes @ 0xE0002014) – CPU_WriteMem(4 bytes @ 0xE0002018) – CPU_WriteMem(4 bytes @ 0xE000201C)
02-00000000-00-00001128-01E4: – CPU_ReadMem(4 bytes @ 0xE0001000) – CPU_ReadMem(4 bytes @ 0x400FC040) – CPU_WriteMem(4 bytes @ 0xE000EDFC) – CPU_WriteMem(4 bytes @ 0xE0001058) – CPU_ReadMem(4 bytes @ 0x00000004) – CPU_ReadMem(4 bytes @ 0xE0002000) – CPU_ReadMem(4 bytes @ 0xE0002008) – CPU_ReadMem(4 bytes @ 0xE000200C) – CPU_ReadMem(4 bytes @ 0xE0002010) – CPU_ReadMem(4 bytes @ 0xE0002014) – CPU_ReadMem(4 bytes @ 0xE0002018) – CPU_ReadMem(4 bytes @ 0xE000201C) – CPU_WriteMem(4 bytes @ 0xE0002000)
02-00000000-00-00001243-01EC: – CPU_WriteMem(4 bytes @ 0xE0002008) – CPU_WriteMem(4 bytes @ 0xE000200C) – CPU_WriteMem(4 bytes @ 0xE0002010) – CPU_WriteMem(4 bytes @ 0xE0002014) – CPU_WriteMem(4 bytes @ 0xE0002018) – CPU_WriteMem(4 bytes @ 0xE000201C) – CPU_ReadMem(4 bytes @ 0xE0001000) – CPU_ReadMem(4 bytes @ 0x400FC040) – CPU_WriteMem(4 bytes @ 0xE0002000) – CPU_WriteMem(4 bytes @ 0xE0002008) – CPU_WriteMem(4 bytes @ 0xE000200C) – CPU_WriteMem(4 bytes @ 0xE0002010) – CPU_WriteMem(4 bytes @ 0xE0002014)
02-00000000-00-00001248-00D3: – CPU_WriteMem(4 bytes @ 0xE0002018) – CPU_WriteMem(4 bytes @ 0xE000201C) – CPU_WriteMem(4 bytes @ 0xE0002000) – CPU_ReadMem(4 bytes @ 0xE000EDFC) – CPU_ReadMem(4 bytes @ 0xE0001000) (0265ms, 0987ms total)
01-0000000A-00-00001248-007C: $52657365747320636f72652026207065726970686572616c7320766961205359535245534554524551202620564543545245534554206269742e0D0A#1f
03-00000000-00-00001248-003A: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
00-0000000A-00-00001249-0036: $qRcmd,72656720723133203d20283078303030303030303029#13
02-00000000-00-00001253-007B: T1D87000 001:252 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 0987ms total)
02-00000000-00-00001253-0064: T1D87000 001:254 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 0987ms total)
02-00000000-00-00001255-00F7: T5607000 001:254 JLINK_ReadMemU32(0x00000000, 0x0001 Items, …) – CPU_ReadMem(64 bytes @ 0x00000000) – Updating C cache (64 bytes @ 0x00000000) – Read from C cache (4 bytes @ 0x00000000) - Data: E0 7F 00 10 returns 0x01 (0002ms, 0989ms total)
02-00000000-00-00001256-005A: T5607000 001:257 JLINK_WriteReg(R13 (SP), 0x10007FE0) returns 0x00 (0000ms, 0989ms total)
01-0000000A-00-00001256-004C: $57726974696e6720726567697374657220285350203d2030783130303037464530290D0A#24
03-00000000-00-00001256-0022: Writing register (SP = 0x10007FE0)
00-0000000A-00-00001256-0034: $qRcmd,726567207063203d20283078303030303030303429#b4
02-00000000-00-00001256-00A5: T5607000 001:257 JLINK_ReadMemU32(0x00000004, 0x0001 Items, …) – Read from C cache (4 bytes @ 0x00000004) - Data: CD 00 00 00 returns 0x01 (0000ms, 0989ms total)
02-00000000-00-00001256-005A: T5607000 001:257 JLINK_WriteReg(R15 (PC), 0x000000CC) returns 0x00 (0000ms, 0989ms total)
01-0000000A-00-00001256-004C: $57726974696e6720726567697374657220285043203d2030783030303030304344290D0A#17
03-00000000-00-00001256-0022: Writing register (PC = 0x000000CD)
00-0000000A-00-00001256-0018: $qRcmd,72656720723133#f9
02-00000000-00-00001257-0053: T5607000 001:258 JLINK_ReadReg(R13 (SP)) returns 0x10007FE0 (0000ms, 0989ms total)
01-0000000A-00-00001257-004C: $52656164696e6720726567697374657220285350203d2030783130303037464530290D0A#18
03-00000000-00-00001257-0022: Reading register (SP = 0x10007FE0)
00-0000000A-00-00001257-0016: $qRcmd,726567207063#96
02-00000000-00-00001259-0053: T5607000 001:260 JLINK_ReadReg(R15 (PC)) returns 0x000000CC (0000ms, 0989ms total)
01-0000000A-00-00001259-004C: $52656164696e6720726567697374657220285043203d2030783030303030304343290D0A#0a
03-00000000-00-00001260-0022: Reading register (PC = 0x000000CC)
02-00000000-00-00001266-007B: T1D87000 001:265 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 0989ms total)
02-00000000-00-00001266-0064: T1D87000 001:267 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 0989ms total)
02-00000000-00-00001281-007B: T1D87000 001:280 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 0989ms total)
02-00000000-00-00001281-0064: T1D87000 001:282 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 0989ms total)
02-00000000-00-00001293-007B: T1D87000 001:292 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 0989ms total)
02-00000000-00-00001296-0064: T1D87000 001:296 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 0989ms total)
02-00000000-00-00001307-007B: T1D87000 001:307 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 0990ms total)
02-00000000-00-00001307-0064: T1D87000 001:308 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 0990ms total)
00-0000000A-00-00001311-000C: $qTStatus#49
01-0000000A-00-00001311-0004: $#00
00-0000000A-00-00001311-000D: $qSymbol::#5b
00-0000000A-00-00001312-000C: $X4000,0:#b2
01-0000000A-00-00001312-0006: $OK#9a
00-0000000A-01-00001313-0800:
{{<<I HAVE REMOVED ALL THE HEXCODES OF THE DOWNLOADED main.elf FILE AS THE PSOT IS TOO BIG OTHERWISE>>}}
03-00000000-00-00001325-002C: Downloading 15040 bytes @ address 0x00013C10
02-00000000-00-00001327-00A1: T5607000 001:328 JLINK_WriteMem(0x00013C10, 0x3AC0 Bytes, …) - Data: 11 9F 05 46 00 2F 05 DD 29 46 50 46 3A 46 00 F0 … returns 0x3AC0 (0000ms, 0995ms total)
02-00000000-00-00001328-00D3: T5607000 001:328 JLINK_ReadMem (0x00013C10, 0x3AC0 Bytes, …) – Read from flash cache (15040 bytes @ 0x00013C10) - Data: 11 9F 05 46 00 2F 05 DD 29 46 50 46 3A 46 00 F0 … returns 0x00 (0001ms, 0996ms total)
03-00000000-00-00001328-000E: - Verified OK
01-0000000A-00-00001328-0006: $OK#9a
00-0000000A-01-00001328-0015: 245831373664302c383a288eff7f01000000233564
03-00000000-00-00001328-0028: Downloading 8 bytes @ address 0x000176D0
02-00000000-00-00001328-0083: T5607000 001:329 JLINK_WriteMem(0x000176D0, 0x0008 Bytes, …) - Data: 28 8E FF 7F 01 00 00 00 returns 0x08 (0000ms, 0996ms total)
02-00000000-00-00001328-00B3: T5607000 001:329 JLINK_ReadMem (0x000176D0, 0x0008 Bytes, …) – Read from flash cache (8 bytes @ 0x000176D0) - Data: 28 8E FF 7F 01 00 00 00 returns 0x00 (0000ms, 0996ms total)
00-0000000A-01-00001328-0143: 245831373664382c3133343a000000000000a041040309040902090000010080fa000000420330003100320033003400350036003700610062006300640065006600670068003000310032003300340035003600370061006200630064006500660067006800000012010002ef020140501d15600001000000010000b80a001000d8b80500000000b0730100d0730100f0730100000000000000000000000000000000001074010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000040010010b4740100c8750100da610100da610100da610100da610100da610100da610100da610100da610100da610100ffffffffffffffffffffffffffff0000f1400000ad45000015470000f1510000e5820000d1b30000cd400000233362
03-00000000-00-00001329-002A: Downloading 308 bytes @ address 0x000176D8
02-00000000-00-00001329-00A0: T5607000 001:330 JLINK_WriteMem(0x000176D8, 0x0134 Bytes, …) - Data: 00 00 00 00 00 00 A0 41 04 03 09 04 09 02 09 00 … returns 0x134 (0000ms, 0996ms total)
02-00000000-00-00001331-00D1: T5607000 001:332 JLINK_ReadMem (0x000176D8, 0x0134 Bytes, …) – Read from flash cache (308 bytes @ 0x000176D8) - Data: 00 00 00 00 00 00 A0 41 04 03 09 04 09 02 09 00 … returns 0x00 (0000ms, 0996ms total)
03-00000000-00-00001331-000E: - Verified OK
01-0000000A-00-00001331-0006: $OK#9a
00-0000000A-00-00001332-000F: $Pf=1de70000#e4
02-00000000-00-00001384-01F2: T5607000 001:333 JLINK_WriteReg(R15 (PC), 0x0000E71C) – -------------------------------------- – Start of determining dirty areas in flash cache – End of determining dirty areas – Start of preparing flash programming – Calculating RAM usage – RAM usage = 5844 Bytes – Preserving registers – Preparing memory – Determining CPU clock frequency – CPU clock frequency: 4063 kHz – CPU frequency = 4063 kHz – Preparing target – Preserving additional used target memory – Downloading RAMCode
02-00000000-00-00001446-01B8: – Using alternate TurboMode RAMCode – Checking target RAM – Preparing RAMCode – End of preparing flash programming – CPU is running at 60000 kHz. – Start of comparing flash – CRC check was estimated as fastest method – Comparing range 0x4000 - 0xFFFF (12 Sectors, 48 KB), using multi-block CRC calculation – All CRCs match – Comparing range 0x10000 - 0x17FFF (1 Sector, 32 KB), using multi-block CRC calculation – All CRCs match
02-00000000-00-00001483-01FD: – Comparing range 0x4000 - 0xFFFF (12 Sectors, 48 KB), using alternative multi-block CRC calculation – All CRCs match – Comparing range 0x10000 - 0x17FFF (1 Sector, 32 KB), using alternative multi-block CRC calculation – All CRCs match – End of comparing flash – Start of erasing sectors – End of erasing sectors – Start of flash programming – End of flash programming – Start of verifying flash – End of verifying flash – Start of restoring – Restore RAMCode – Restore content of target memory
02-00000000-00-00001489-0196: – Restore target – Restore memory – Restore content of registers – End of restoring – Flash download into internal flash skipped. Flash contents already match – Flash download into internal flash skipped. Flash contents already match – Total time needed: 0.153s (Prepare: 0.081s, Compare: 0.061s, Erase: 0.000s, Program: 0.000s, Verify: 0.000s, Restore: 0.011s) returns 0x00 (0157ms, 1153ms total)
03-00000000-00-00001489-0022: Writing register (PC = 0x0000e71d)
01-0000000A-00-00001489-0006: $OK#9a
00-0000000A-00-00001489-000C: $qTStatus#49
01-0000000A-00-00001489-0004: $#00
00-0000000A-00-00001490-001D: $qXfer:threads:read::0,fff#03
01-0000000A-00-00001490-0005: $l#6c
02-00000000-00-00001490-007B: T1D87000 001:490 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1153ms total)
02-00000000-00-00001490-0064: T1D87000 001:491 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1153ms total)
02-00000000-00-00001504-007B: T1D87000 001:504 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1153ms total)
02-00000000-00-00001505-0064: T1D87000 001:505 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0001ms, 1154ms total)
02-00000000-00-00001516-007B: T1D87000 001:516 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1154ms total)
02-00000000-00-00001517-0064: T1D87000 001:518 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1155ms total)
02-00000000-00-00001532-007B: T1D87000 001:529 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1155ms total)
02-00000000-00-00001532-0064: T1D87000 001:533 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1155ms total)
02-00000000-00-00001545-007B: T1D87000 001:544 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1155ms total)
02-00000000-00-00001545-0064: T1D87000 001:546 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1155ms total)
02-00000000-00-00001558-007B: T1D87000 001:558 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1155ms total)
02-00000000-00-00001559-0064: T1D87000 001:560 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001572-007B: T1D87000 001:570 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001572-0064: T1D87000 001:573 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001586-007B: T1D87000 001:586 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001586-0064: T1D87000 001:587 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001598-007B: T1D87000 001:598 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001598-0064: T1D87000 001:599 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001613-007B: T1D87000 001:612 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001613-0064: T1D87000 001:614 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001629-007B: T1D87000 001:629 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001629-0064: T1D87000 001:630 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001642-007B: T1D87000 001:640 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001643-0064: T1D87000 001:644 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001660-007B: T1D87000 001:658 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001660-0064: T1D87000 001:661 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001673-007B: T1D87000 001:673 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001673-0064: T1D87000 001:674 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1156ms total)
02-00000000-00-00001688-007B: T1D87000 001:686 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1156ms total)
02-00000000-00-00001689-0064: T1D87000 001:690 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001703-007B: T1D87000 001:701 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001703-0064: T1D87000 001:704 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001720-007B: T1D87000 001:719 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001720-0064: T1D87000 001:721 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001735-007B: T1D87000 001:732 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001735-0064: T1D87000 001:736 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001749-007B: T1D87000 001:748 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001749-0064: T1D87000 001:750 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001760-007B: T1D87000 001:760 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001760-0064: T1D87000 001:761 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001772-007B: T1D87000 001:771 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001772-0064: T1D87000 001:773 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001784-007B: T1D87000 001:784 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001784-0064: T1D87000 001:785 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001796-007B: T1D87000 001:796 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001796-0064: T1D87000 001:797 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001808-007B: T1D87000 001:807 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001808-0064: T1D87000 001:809 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001822-007B: T1D87000 001:820 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001822-0064: T1D87000 001:823 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001834-007B: T1D87000 001:833 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001834-0064: T1D87000 001:835 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001852-007B: T1D87000 001:849 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001852-0064: T1D87000 001:853 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001870-007B: T1D87000 001:867 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001870-0064: T1D87000 001:871 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001881-007B: T1D87000 001:881 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001881-0064: T1D87000 001:882 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
02-00000000-00-00001899-007B: T1D87000 001:896 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001899-0064: T1D87000 001:900 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
03-00000000-00-00001911-001C: GDB closed TCP/IP connection
02-00000000-00-00001913-007B: T1D87000 001:910 JLINK_SWO_Read(…, Offset = 0x00, NumBytes = 0x80000) - Data: NumBytesRead = 0x00 (0000ms, 1157ms total)
02-00000000-00-00001913-0064: T1D87000 001:914 JLINK_SWO_Control(JLINKARM_SWO_CMD_FLUSH, …) returns 0x00 (0000ms, 1157ms total)
