hi all!, i have a problem, i have a pdf file that i need to use in lightburn, so i use inkscape to transfor the pdf into svg or dxf but everything that i do that strange things happent with the file
this is the pdf
and this is the dxf and svg
after a full day trying to solve this i try to use one of this online web that make the conversion from pdf to dxf, is work good, but the problem is that when i do that i make a double lines that the original pdf don’t have, and i think is impossible to deleted that double lines
example
thanks !!
