Trying Repetier to run break in code. gcode is loaded but won’t run. I wish their was a customer support for this… Can someone share their screen shot’s of their repetier configuration? Maybe I am missing something?
UPDATE: I uninstalled the old repetier version and installed the newest version. I also used the web based configuration wizard. When I submit the break in g-code manually I get the following error…" CONNECTION LOST - Uups! I lost connection to the server. Trying to reconnect". When I open Repetier , I am able to connect to the printer and control it manually.
@Gus_Montoya if you’re searching for customer support you’d probably have better gone with a commercial printer.
edited
ERR, sorry, didn’t see the second part of your updated message. What do you mean by “submitting manually”? Don’t use an older version of Repetier - that won’t change anything and the newer version should work as well. Can you tell what the log window says if you just load the break in code and hit start? You can paste it to http://pastebin.com and paste the URL here if it’s too long and you don’t know what the important part is. It would probably be good to have a complete log from connection to print start to help you better.
@Gus_Montoya aren’t you using a smoothieboard? If so the web firmware config won’t help. That is for repetier firmware which I don’t think runs on the smoothieboard.
oh i was totally overreading that web configuration part. Of course the Repetier Firmware is not for you Smoothieboard - that only runs with the Smoothieware - but you should have already noticed that part in the board selection dropdown of the Repetier Configurator.
