Totally stumped, had an ESP2866 set up with with a strip of APA102's and
Totally stumped, had an ESP2866 set up with with a strip of APA102’s and it was working fine, then the client threw out the board (long story) and I had to rebuild it. Same code, same hardware, but it wont compile. Trying other pins has similar issues, here is the error:
Arduino: 1.6.4 (Mac OS X), Board: “WeMos D1 R2 & mini, 80 MHz, 115200, 4M (3M SPIFFS)”
In file included from _20Mission_BETA_v1.4.ino:75:0:
/Users/tennischannel/Documents/Arduino/libraries/FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.001
pragma message “FastLED version 3.001.001”
In file included from /Users/tennischannel/Documents/Arduino/libraries/FastLED/FastLED.h:65:0,
/Users/tennischannel/Documents/Arduino/libraries/FastLED/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
pragma message “No hardware SPI pins defined. All SPI access will default to bitbanged output”
In file included from /Users/tennischannel/Documents/Arduino/libraries/FastLED/FastLED.h:48:0,
/Users/tennischannel/Documents/Arduino/libraries/FastLED/fastpin.h: In instantiation of ‘class FastPin<14u>’:
/Users/tennischannel/Documents/Arduino/libraries/FastLED/fastspi_bitbang.h:22:49: required from ‘class AVRSoftwareSPIOutput<14u, 12u, 6u>’
/Users/tennischannel/Documents/Arduino/libraries/FastLED/fastspi.h:30:7: required from ‘class SPIOutput<14u, 12u, 6u>’
/Users/tennischannel/Documents/Arduino/libraries/FastLED/chipsets.h:94:6: required from ‘class LPD8806Controller<14u, 12u, (EOrder)136u, 6u>’
/Users/tennischannel/Documents/Arduino/libraries/FastLED/FastLED.h:240:77: required from ‘static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with ESPIChipsets CHIPSET = (ESPIChipsets)5u; unsigned char DATA_PIN = 14u; unsigned char CLOCK_PIN = 12u; EOrder RGB_ORDER = (EOrder)136u]’
_20Mission_BETA_v1.4.ino:262:72: required from here
/Users/tennischannel/Documents/Arduino/libraries/FastLED/fastpin.h:206:2: error: static assertion failed: Invalid pin specified
static_assert(validpin(), “Invalid pin specified”);
/Users/tennischannel/Documents/Arduino/libraries/FastLED/fastpin.h: In instantiation of ‘class FastPin<12u>’:
/Users/tennischannel/Documents/Arduino/libraries/FastLED/fastspi_bitbang.h:23:50: required from ‘class AVRSoftwareSPIOutput<14u, 12u, 6u>’
Error compiling.
This report would have more information with
“Show verbose output during compilation”
enabled in File > Preferences.
Ran into the same issue recently. I was using pin 13 which is D7 on the wemos mini. I changed the number in the code to 7 and then it started working just fine. Try using the same number that’s listed on the wemos pin.
