Tom’s BBC micro:bit Shell V1 – Simple Case for Simple Microcomputer
Small closed case designed today from scratch and ready for your #3Dprinting. No screws or glue needed. Two parts, 0.2mm (or 0.1) layers, standard 0.4mm nozzle. Print the upper part from clear material (Crystal Clear PLA from @Fillamentum1 did the work in my case) to see the LEDs. You can use multicolour print for more attractive box.
#BBC #microbit #Fusion360 #Thingiverse #electronics #diy #Prusai3
http://www.thingiverse.com/thing:1692680
