LaserWeb information
On the About page, I see that I have:
- Frontend version: 4.0.998
- Backend version: 4.0.136
My settings are:
"settings": {
"__version": "4.0.998",
"__selectedProfile": "*gen_grbl",
"__latestRelease": "2019-11-26T10:42:57Z",
"showMachine": false,
"machineWidth": 300,
"machineHeight": 200,
"machineBeamDiameter": 0.2,
"machineBottomLeftX": 0,
"machineBottomLeftY": 0,
"machineFeedRange": {
"XY": {"min": 1, "max": 50000},
"Z": {"min": 1, "max": 50000},
"A": {"min": 1, "max": 50000},
"S": {"min": 0, "max": 30000}
"machineXYProbeOffset": 0,
"machineZEnabled": false,
"machineZMatThickness": 0,
"machineZToolOffset": 0,
"machineZStartHeight": "",
"machineZProbeOffset": 0,
"machineAEnabled": false,
"machineBlowerEnabled": false,
"machineBlowerGcodeOn": "",
"machineBlowerGcodeOff": "",
"pxPerInch": 96,
"forcePxPerInch": false,
"dpiBitmap": 300,
"toolGridWidth": 400,
"toolGridHeight": 300,
"toolGridMinorSpacing": 10,
"toolGridMajorSpacing": 50,
"toolSafetyLockDisabled": false,
"toolCncMode": false,
"toolImagePosition": "BL",
"toolUseNumpad": false,
"toolDisplayCache": false,
"toolUseGamepad": false,
"toolCreateEmptyOps": false,
"toolVideoDevice": null,
"toolVideoPerspective": {"enabled": false},
"toolVideoLens": {"a": 1, "b": 1, "F": 1, "scale": 1},
"toolVideoFov": {"x": 1, "y": 1},
"toolVideoResolution": "720p(HD)",
"toolVideoOMR": false,
"toolVideoOMROffsetX": 0,
"toolVideoOMROffsetY": 0,
"toolVideoOMRMarkerSize": 20,
"toolWebcamUrl": "",
"toolFeedUnits": "mm/min",
"toolTestSValue": 1,
"toolTestDuration": 0,
"gcodeStart": "G21 ; Set units to mm\r\nG90 ; Absolute positioning\r\nM4 S0 ; Enable Laser/Spindle (0 power)\r\n",
"gcodeEnd": "M5 ; Disable Laser/Spindle\r\n",
"gcodeHoming": "$H",
"gcodeGenerator": "default",
"gcodeToolOn": "",
"gcodeToolOff": "",
"gcodeLaserIntensity": "S",
"gcodeLaserIntensitySeparateLine": false,
"gcodeSMinValue": 0,
"gcodeSMaxValue": 1000,
"gcodeCheckSizePower": 0,
"gcodeToolTestPower": 0,
"gcodeToolTestDuration": 0,
"gcodeConcurrency": 2,
"gcodeCurvePrecision": 0.1,
"comServerVersion": "4.0.136",
"comServerIP": "localhost:8000",
"comServerConnect": false,
"comInterfaces": ["USB", "ESP8266", "Telnet"],
"comPorts": [
"comName": "COM5",
"manufacturer": "Arduino LLC (www.arduino.cc)",
"serialNumber": "75439333435351A05061",
"pnpId": "USB\\VID_2341&PID_0043\\75439333435351A05061",
"locationId": "Port_#0009.Hub_#0003",
"vendorId": "2341",
"productId": "0043"
"comName": "COM4",
"manufacturer": "FTDI",
"serialNumber": "DN02CYYW",
"pnpId": "FTDIBUS\\VID_0403+PID_6015+DN02CYYWA\\0000",
"vendorId": "0403",
"productId": "6015"
"comName": "COM3",
"manufacturer": "Intel",
"pnpId": "PCI\\VEN_8086&DEV_8C3D&SUBSYS_2255103C&REV_04\\3&B1BFB68&0&B3",
"locationId": "PCI bus 0, device 22, function 3"
"comAccumulatedJobTime": 0,
"connectVia": "USB",
"connectPort": "COM4",
"connectBaud": "115200",
"connectIP": "",
"jogStepsize": 1,
"jogFeedXY": 1800,
"jogFeedZ": 300,
"macros": {
"*GotoXY0": {
"label": "Goto XY zero",
"gcode": "G0 X0Y0",
"keybinding": "ctrl+f1",
"_locked": false
"*LaserOff": {
"label": "LASER OFF",
"gcode": "M5",
"keybinding": "ctrl+f2",
"_locked": false
"uiFcDrag": null
Problem description
I can’t connect Laserweb with the Tinyg…
Does I have to activate something on the TinyG to make the connection ?
I’m getting the following error :
Connecting Machine @ USB,COM4,115200baud
Machine connected
No supported firmware detected. Closing port COM4`
This problem has always happened.
But I can perfectly send Gcode to the controller via Coolterm or
System description
A custom made CNC controller with a laser on the same head. The whole things is controlled with a TinyG
I have a TinyG
Firmware build : 440.20 version 0.97 installed
I connect via USB
My computer(s) on which I run LaserWeb run(s) Win 10 64bits version
Here is my configuration:
