This stuff it really stretchy! anyone use this stuff yet?
Originally shared by David Clunie
NINJAFLEX filament! It STRETCHES!
http://www.dbclunie.com/2013/10/video-ninjaflex-filament-its-stretchy.html
How the heck do you push that through the extruder/hot end? Seems like pushing a wet noodle!
Never going to work with a Bowden set up (I imagine).
they have a FAQ on their page and show a example of an extruder that would should work, looks similar to a whthomas upgrade/spring type exstruder, thought it looks like the initial wheel is more of a pointed gear type than just a smooth grove end on the stepper motor. Also I think the temp is extremely low for melting… will let you guys know when i try and print out a sample chip once i get my printer fixed.
@David_Clunie I’m having quite good luck with 3mm NinjaFlex, filament, using a Wades extruder on a Mendel90.
Here are couple of tips for using it I learned along the way:
Sounds like it might print nice shoes
I didn’t even realize @MakerBot1 had a flexible filament too. I am going to have to try this NinjaFlex to see if it works on my Replicator. Looks awesome!!
