This looks like interesting material to cut.
I assume its safe?? (polyethylene foam (PE foam or PEF)).
When searching for same on amazon I found this:
From what I’ve read online, PE is generally unsafe to cut, but I’d guess with the right settings, it should be ok. I think what I mostly saw was about it melting and catching fire, but I’m going off memory at the moment, so don’t quote me on that.
