This is my first attempt to mill a PCB with Cilipeppr,
This is my first attempt to mill a PCB with Cilipeppr, I used 45 degree V-bit to mill the traces, I only have 0.6mm drill bit, so I used it to drill the small holes and I milled bigger holes and cut the board with 1.5mm bit.
Board designed in Eagle, CP generated the gcode, I manually wrote the gcode for drilling the holes.
I’m very happy with the result, Auto level did excellent job here.
Looks great. Now the CP Eagle BRD widget in the TinyG workspace generates the drills automatically for you. I assume you’re Grbl, so that workspace is behind. However, the xpix workspace does have a Grbl version with drills.
Happy to hear that, my TinyG board is on the way, hopefully in a week or so I’ll work mainly on TinyG workspace.
