To jump, both of the insect’s hind legs must push forward at the exact same time. Because they both swing laterally, if one were extended a fraction of a second earlier than the other, it’d push the insect off course to the right or left, instead of jumping straight forward.
The gearing is an elegant solution. The researchers’ high-speed videos showed that the creatures, who jump at speeds as high as 8.7 miles per hour, cocked their back legs in a jumping position, then pushed forward, with each moving within 30 microseconds (that’s 30 millionths of a second) of the other. The finely toothed gears in their legs allow this to happen
Interesting! Thanks for sharing!
