This bed probing is quite annoying.
(corexy, H slaved, inductive probe as homing and probe)
The probing distance is off by +40%
G30 will also crash if I don’t move the bed above, then zero.
g0 z5, g92
I’m trying to go through the code. I’m a novice at programming but I want this bed leveling working!
I guess it’s still possible I’ve made a mistake in config somewhere…
It’s difficult to make a G29 that works for all printers, so it needs to be very flexible. That also makes it a bit difficult to configure, but it should be possible with some trial and error.
Check G29.2 to generate a probing routine that works for you.
I just about made one but I guess I have to fudge the offsets to get it to work. I was just using the default 3 points but was hoping to solve the odd: distance moved is not equal to distance probed. The default 10mm = -14.14mm probed distance
I’m updating everything right now, see if that changes anything. I’m reading as much as I can on github
That’s in your steps per millimeter settings you want to change it
I’m using m114 as reference. They should be exactly the same, steps_per_mm wouldn’t matter. In debug it says 4000 steps, which is correct.
steps per mm * micro * 10mm
251610
Well… Good news. The RC branch fixed it. 2.2.dev0+69.rc.g7637fc8
If I move 5, it reads -4.94mm. Perfect.
Be aware that the RC branch is getting more updates and we’ll try to put out an image with it soon!
Yeah, I saw that the endstop alarms has been changed too. I had used two optical endstops to stop the rotation of Z and H so I can level the bed. One side of the bed slouches. Now I cant because it pauses moves. There’s so many printers with dual Z motors but It’s always a hassle…
Maybe I’ll find some way to use the inductive probe to level it… More experimenting…
Well, you can still do that if Z & H are not slaved… Z1_stops = z_ccw, Z2_stops=h_ccw should work?
There’s an M-code command to activate slaving too - maybe make a custom G29 routine that decouples H & Z, sets the Z1 and Z2 triggers as above, then re-slave and “standardize” your Z1 and Z2 triggers?
Yeah, I might do that. I also just bought some bearing blocks. I was just thinking about belting the two leadscrews together and sneak it under the bed so I don’t have to suffer syncing the the two motors. It’ll save a lot of time too I bet. I kinda wish there was a bed compensation that would sync the two motors based on the readings it got and some geometry inputs.
