The true Black Panther (it's actually a reproduction from an Egyptian sculpture,
The true Black Panther (it’s actually a reproduction from an Egyptian sculpture, the Gayer-Anderson Cat). Correct cooling fan position make a hell of a difference for sure. Also trying the mini-hot-end from Deltaprintr. Nice, but a little noisy. Will try to improve this later aspect…
The blue part in the video is actually PETG. I like it a lot, but I find some object are just better with the dark contrast that PLA provide. Its also stiffer (and more brittle).
(and I can’t afford 10 kg a week now). Where are you getting yours?
The problem is that I was once my own employee and I intend to stick with this philosophy. It’s hard to go back (but eventually will when I’ll run out of $$$), until then I’ll try… :wink:
