The printer gods are smiling on me tonight! This is a cam for a Halloween prop. I drew it up in sketch up with 1/4" square holes, told kisslicer to do one perimeter instead of three, and to inset surface 0.15mm…it’s a solid friction fit!
All good advice!
@Shauki A part I print for others as a camera mounting system is ABS at 50% infill is routinely tapped for 1/4-20 bolts. Nylon will thread but tools need to be VERY sharp ! [e.g. Nylock nuts] PLA is too brittle to reliably hold a thread.
