The H-1 gets ailerons. Next rudders and elevators, retractable landing gear, framing. Requesting help with design and sourcing parts. For example, what are we going to use for a landing gear? Retractable? Is there anything off the shelf that will suit our needs? http://a360.co/1QoKKpV
[Edit] The OpenRC H-1 project is a collaborative development exercise. We are creating a single large 1/4 scale 3D printed aircraft model as a group. Distributed development.
It’s a semi-complicated process in fusion 360 that results in a spiral print. Inside structure and outside form fuse together with carefully applied splits so close that it welds itself into one structure.
