The design changed a lot since I last posted it to this group. It’s nearly finalized, I can’t think of any more bugs for it at the moment.
Originally shared by Stephanie A
Fixed a bug with the Y rods not coming out the right height. Fixed a couple other bugs too. Changed the bearing clamps. Also added the greatest thing of all: printed feet!
I tested the parameters and everything seems to work. I have a couple basic extrusion sizes already entered, the only critical dimensions are the extrusion width and mounting screws.
You input the extrusion lengths depending on the dimensions you want the machine to be. There are 5 lengths that are calculated (i might change this so only 3 are calculated)
The x carriage is prusa i3 compatible. It does not fit the vertX standard. A future upgrade would be to allow it to be compatible.
The extruder mounts through 2 mounting holes.
What is the “VertX Standard”? (edit: I answered my own question. nm)
