Thanks to Ray for getting me the .BIN and the Config file for 4
Thanks to Ray for getting me the .BIN and the Config file for 4 axis.
All loaded up ok.
Connected up A and Z axis (see photos)
Z is no problem and moves as it should.
A moves but does not show any movement on screen. I can jog via Laserweb4.
(please see video https://www.youtube.com/watch?v=Zc0USKY-g7A)
There is also no A on the reprap screen . I mostly run from screen as a standalone.
when I post a program with A moves it looks ok on Laserweb4 but the program stops at the first A move,
What am I missing?
I have swapped over the drives and motors, always shows correct with Z and no readout with A axis.
If i load the Gcode to the board then it will run and A moves but still no readout on screen in laserweb4.
This makes me thing its a laserweb problem?
Running latest version of all software
Help please.
What do you expect to move on a X/Y/Z screen, when A moves?
Would expect the A to move to show where it is
Ah, you mean the DRO, not the blue cursor on the right.
That looks like your firmware isn’t reporting the A axis position in the position messages, or LW4 doesn’t detect them correctly.
