thanks
I pulled up the specs on the board and it said it could handle 12-48 volts. I just didn’t know what the optimal was. I guess I’ll go with 40 volts.
Originally shared by Dale Maxim
I need some quick help with my Ox. My original power supply ( 400 w- 48 v) quit. I have a new one but don’t know what voltage output to set it to. Could someone please let me know so I can get it running again. I’m using an M1 board if that makes a difference.
I assume you mean a Gradus M1 board. The board specs are less important than the voltage rating of the stepper drivers. Check the specs on your stepper drivers, this is what will limit your maximum voltage. If they are rated at, say, 40V, set your power supply somewhat less than this rated voltage, as the motors can generate higher voltages on deceleration etc. You need a bit of cushion to allow for this. I would say around 10% lower than the driver rating at least.
