Testing engraving  on aluminium, 3mm engraving bit using Linux Cnc.
wow! this is very cool!
Thanks.
That’s cool Steve got to love Dragons
The object of this exercise was to see how accurate i could reproduce curves and fine detail with my setup on a small scale as indicated by the size of the keys on the keyboard.
Tomorrow Pinky - we will try to take over the world!
Wow, very beautiful dragon!
I use too Linux Cnc from few years: never disappointed by this soft…Always Perfect!
60 deg V-Bit. 0.04 depth. About 80mm/minute feed rate. Spindle speed = as fast as my little 300w
will go and lots of silicon spray which seems to work a bit better then WD-40.
@Steve_Slese I have heard candle wax is a good lubricant for cutting aluminium. I will have to give it a try. But I will keep silicon spray in mind and I use WD40 for tapping holes.
Slow and steady :slight_smile:
