I was able to download and compile Marlin with Platform IO, i was also able to upload to my Arduino Mega board, I dont know how to test it.
In past I tested GRBL with Universal G Code Sender but i was not able to connect Marlin with UGS. I want to know what software can i use to TEST G Code commands.
Please note that I’m not going to use it with 3D Printer, I’m going to build a different machine want use X,Y axis and switching on/off modules.
Please also advise how can i configure Marlin through commands like we can configure GBRL from UGS software? like $25 command etc.
You need a suitable program so you can send g-code commands over the USB connection. pronterface is a good one to use even if you aren’t using a 3d printer.
Well, UGS is Universal Gcode Sender and for firmware it supports, allows you to send gcode. But the reason it wouldn’t work with Marlin is that it doesn’t support Marlin yet:
However, a lot of Marlin configuration is done at compile time:
Here is the Marlin gcode reference:
It has M commands for configuration listed there, including M500 (save settings) but much of what grbl exposes as $ settings is compiled into Marlin.
