SVG problem.
Hi see pic, how can I solve this?
The lines don’t meet.
It is a closed path soo it should not happen i believe.
SVG problem.
When I rotate the image 90 degrees it is gone because LW is using a different path.
You sure it’s not just that bit of raised wood grain altering the laser path slightly?
No, did it many times and it’s every time the same.
Also, when I make the logo bigger it’s gone.
Wondering what it can be.
Also tried different speeds, no change?
@Hans_Messbauer wait, when you scale the logo it goes away?
Then there’s an error in the file. Try running the original through SVGcleaner and see if that helps.
Hi christopher,
Actually it doesn’t, my mistake.
Tried everything now, can’t solve it.
Here you have some images and files, maybe you can sort it out.
And a screenshot of LaserWeb, . .
