Support from gcode experts needed:
When I manually set all axes to 0 [1], then the printer only “draws” a quarter of the ring (machine center at 0,0). It seems like it could not print into negativ directions [2]. There are no such problems when the machine homes as usual.
Question: May I have set wrong machine limits [3], end points or something else?
;[1]
G92 X0 Y0 Z0 E0 ;zero XYZE
G0 F1800 X2.998 Y-7.267 Z1.000
G0 X3.436 Y-8.296
G1 F900 X6.350 Y-6.350 E0.01224
G1 X8.296 Y-3.436 E0.02448 [2]
G1 X8.980 Y0.000 E0.03672
G1 X8.296 Y3.436 E0.04896
G1 X6.350 Y6.350 E0.06120
G1 X3.436 Y8.296 E0.07344
G1 X0.000 Y8.980 E0.08567
G1 X-3.436 Y8.296 E0.09791
;[2]
G1 X-6.350 Y6.350 E0.11015
G1 X-8.296 Y3.436 E0.12239
G1 X-8.980 Y0.000 E0.13463
G1 X-8.296 Y-3.436 E0.14687
G1 X-6.350 Y-6.350 E0.15911
G1 X-3.436 Y-8.296 E0.17135
G1 X0.000 Y-8.980 E0.18358
G1 X3.436 Y-8.296 E0.19582
G0 X0.831 Y-4.024
G1 F600 E0.09582
G0 F1800 X0.831 Y-4.024 Z6.000
M84
[3] M501 listing (partially):
< echo:Home offset (mm):
< echo: M206 X0.00 Y0.00 Z0.00
< echo:Min position (mm):
< echo: M210 X0.00 Y0.00 Z0.00
< echo:Max position (mm):
< echo: M211 X152.40 Y152.40 Z-150.00
< echo:Bed probe offset (mm):
< echo: M212 X25.00 Y0.00 Z-1.40
