Hello Makerforum!
Question: Is it possible to make Smootbieboard execute commands in real time that were sent over Ethernet?
Problem: Smoothieboard seems to collect a number of commands before executing them.
Background: I’m trying to make a 3D printer-attachment for a Universal Robots UR10 arm. The robot controller runs a script that moves the printer head. With every move, the robot controller sends a Gcode command to Smoothieboard to control the extrusion of the plastic. In this setup, Smoothieboard follows the timing of commands set by the robot controller by executing the Gcodes in real time.
To test if this workflow is possible, I made a test-script that runs on the robot controller. It opens a Ethernet (telnet) socket connection and sends relative extrusion commands to Smoothieboard. During the first 7 loops nothing happens, regardless of loop speed. On the 8th loop, 7 extrusions are executed on Smoothieboard. The extrusion motor spins 7 times. If I re-run the script, the same pattern repeats itself over and over. If I make the script run 7 times or less, nothing happen, even when running the script multiple times.
It seems related to the following topics, although I’m not sure it’s the cause of the problem.
- uIP (micro IP) delayed acknowledgement, although here they’re talking about a time delay rather than the problem I described above.
- The $J command. This command allows to bypass the queue, but it seems to be limited to motion on the XYZABC axes.
- Command queue.
- planner module lookahead. I didn’t find a way if it was possible to disable the lookahead function. I’m not sure if lookahead is even used for the extrusion motor.
Here is the test-script: (dashes instead of tabs)
Beforestart
——connection=socket_open(“192.168.185.222”,23)
——Loop connection=False
————connection=socket_open(“192.168.185.222”,23)
————wait: 0.5s
Robot Program
——Loop 8 times
————Wait: 0s
————Socket_send_string(“M83 G1 E3 F2000”)
————Wait: 0
——Halt
Does someone know in what direction I should look?
Thank you for your time!
Elias
