All,
I have a small stack (10) of spent fillament spools.
I 3D printed 8 individual spool boxes and the plastic pins for said spool boxes.
Similar to the below thingiverse.
Is there a guide or a process to print and assemble these Spool Storage units based on the size of the spool.
The reason I am asking is the 4 boxes per spool seem to be slightly too large for my spent Spools. (Before Assembly)
I assemble, correct me if I am wrong, by using a drill press to drill 4 holes in the spent spools through both sides of spool. Use the pins through the holes into the boxes holes.
Once assembled the final box always seems to large.
Do I scale down? Is there some website you plug in the spool dimensions and it generates a properly sized box set (4)? Some standard set of calculations and scaling?
Trying to stay on top of the spools I have not recycled.
Thanks for the help,
Chris
