I was actually looking at buying one myself. The LO air assist head measures 25mm just above the K40 mounting plate and 20mm below. So the 24.5mm one looks like it would work mounted above the plate.
@Nedman thanks Ned, i was wondering on the measurements of the LO head. Mine is still in the mail so I don’t have it yet to measure.
Is this what you were thinking? (ignoring the fact the image shows a stock head instead of an LO heaD)
If so, if mounted here it looks as if it would clear the mounting plate OK.
Yes that is what I was thinking, but you need to keep in mind that the LO head has a smaller diameter then the stock K40 head so there will be a bigger gap between the head and the edge of the plate.
Does anyone have any info on wiring one of these up? Can I get 5V from the power supply or M2 Nano board? (Is it possible to have it turn on at the times when the laser is meant to be firing, even when the laser is turned off?)
@Pippins_McGee Thanks for the info.
Also, can anyone tell me (a totally non-electronics person) what is the best/proper way to connect the wires for the red dot laser to the pins on the M2 Nano board? I assume that the red dot laser will just come with bare wires and I will have to handle the connection myself. I was thinking that something like http://www.ebay.com.au/itm/162038052220 or http://www.ebay.com.au/itm/162014613300 would work.
