Sometimes you slice and print something which you would like to print again after a while. But you’re stuck with gcode and stl file and you haven’t no idea which parameters for slicing you chose. The object was great and you have no nerves to test many possibilities again.
Is there any software which could retrieve this parameters from gcode file?
I know Cura has the option of importing settings from a gcode file, but as mentioned above, that might only be if the settings used are listed in the actual gcode file.
