Some #Saintflint rendered with the free OneRender plug-in from the Onshape App store…
Exist daylight curing resin… need only hi res z, ips display and trasparent Teflon container
Exagerate…dedicated room…full light protect case and when need play with resin turn off all light and close windows same In past when play with phography acid.
Using an MK7 gear, mine’s still extruding well. It’s an excellent design which makes for a CHEAP extruder…I like cheap!
That was RESEARCH!
