Some progress on my 1:1 blackops Locus build
The optics. Bouth the Big knob’s and the focus ring are turnable. Working on the stand next then the main Gun.
Do you have the stls for these. Could put somthing like that on my paintball fun just for looks
@Matthew_Del_Rosso yes i do i was planning to releas them as a complete set…
@Imko_Beckhoven_van ok thanks. It looks pretty sick. Couldnt tell if it was 3d printed at first
That scope shade looks massive. What were you modeling this after?
@MadMetalManiac74 Its the Locus from Black ops 3 the scope is about 32cm i beleven the Total length if the Gun is about 110 cm. So yes its Big
still a lot of sanding to do.
@Marcus_Wolschon not planning on it. No sanding No paint 3 colors of filament and some glue. Of course if you want to make it “perfect” it takes lots and lots of sanding
@Imko_Beckhoven_van
What distance will it be looked at?
@Marcus_Wolschon its just for fun, not aiming for perfection. Even the model’s are low res there direct exports of the game (witch is low res) i made the MR16 (http://www.thingiverse.com/thing:1729262) and the Razorback (http://www.thingiverse.com/thing:1657532) both to give away now i am making the locus for myself… ill share the stl’s so anybody that has the time can take it to the next level.
