Some better pictures of the first Smartcore assembly ! better with light isn’t it ?
I’m quiet happy with the design because it does what i expected : nothing to do on the wood parts ( no holes, no cut) and a VERY simple assembly ( separated XY and Z stages.
From first tests, it seems also work very good !
Seal the wood against absorbing or releasing moisture. Wood will change shape due to moisture absorption, and you will have to make frequent adjustments to keep it working.
Yes dale, i heard about that for the wood. I’m going to see that by myself. I doubt a little it makes so much troubles with all those thousands ultimakers out there with people happy about them ? But it can be only better with sealing the wood.
It will be also quiet easy to make a metal box from it, as this design doesn’t need any operation on the box itself.
Hi Javier,
Smartrap is in constant evolution and debugging, did you follow on thingiverse ? or forums ? ( reprap forum or our own). It’s better place than here for reporting problems.
