So, currently running the newest version of whisperer (.27?) that is out. The issue I’m seeing is when it rehomes after a raster engraving. It hits the stop kinda hard, which throws it out of alignment. This is directly affecting raster engraving with multiple passes. What I’ve resorted to doing is manually reinitializing/rehoming after a single pass to start the following pass to avoid the misalignment. This problem affects vectoring and rastering directly after a raster engraving unless manual reinitialization/rehoming is done. How can I help troubleshoot this issue?
I see what was happening. I uploaded version 0.29 which should resolve the issue. Thanks ‘Akai’ Coit for the detailed description of what was happening and when it was happening. Someone else tried to report this issue yesterday but I couldn’t tell when it was happening from the description they provided. (so I was checking the wrong thing.)
@Scorch Sorry for the late reply. I am not getting notifications of responses to my posts here, so I have to remember to actively check things. I will download and try the newest version and let you know if it fixes the problem for me. Thanks for working on this. Glad I can help find bugs (and describe them effectively enough for you to figure out what’s going on). I’ll keep going until everything is perfect!
