Image unintentionally engraved in reverse when using Halftone (k40 Whisperer).
(Problem seems to have gone away with software updates, but still keeping an eye on it.)
So what I’m occasionally running into is when using halftone (to engrave many small images with gradients and shading), the machine will randomly decide to reverse the image engraving. I choose the opton of engraving from bottom to top by default. What will happen is in mid engraving, the machine will switch direction and go from top to bottom, overwritting the already engraved surface. When stopping the process manually and starting a new one, the engraving will still go from top to bottom reversing the image, starting at the original “0” location of the bottom of the image (imagine making a mirrored image below the original image in question). This flaw does not correct itself until I turn off halftone (which I just did when I decided to do another project instead of the one I was just working on). I do not know if turning halftone back on and trying again will give me the same results of the reversed image, but will test shortly so I can give feedback on that specifically. Any suggestion on what I can provide to help troubleshoot this problem?
No, I am looking for a sample input file that has the problem when it is run. (And a settings file with the settings saved from when the problem occured.)
How common is the problem approximately? 50% of the time 10% of the time or 1% of the time?
So far, top-down engraving seems to be working perfectly fine. Not one error in halftone and when moving from one object to another, it skips the open space (which it does not do in bottom-up mode). So, for now, I will be sticking with top-down. I wan’t call this “fixed” just yet, though. I wanna run with this for a while to see if either of the issues happen at all in top-down mode.
6 days with the only issue ever coming up happening today (odd vector issue where system mistook coordinates for one object and tried to derail… did fewer pieces simultaneously and that issue wasn’t there). The issues in relation to the original post have not shown up yet.
Typically when people report the laser head trying to move out of the laser working area it has been caused by a feature in the SVG file that was not intended located off of the design area.
Finally got around to updating to the newest version of whisperer. The bottom up engraving issue seems to have completely disappeared but I have a new issue now that I find interesting. I will start a new thread about it so as not to migrate this one away from the core issue I started it for.
