[Solved] Building wilson ts here. need some help with flashing marlin firmware. I followed all the configuration.h from Marty’s github and then when I hit compile, I get this error saying
“Marlin.h:219: error: ‘NUM_AXIS’ was not declared in this scope”
and I don’t know what this means… anyone can help? much appreciated thx
Probably a bad download. Also try to compile it BEFORE modifying the files. Just to make sure that it is good. One more thing is to make sure you are using the Arduino IDE version 1.0.6. Using other versions can cause weird errors.
@Step_Cia I went round and round with Marlin 1.0.2 before I remembered reading about the IDE version. I too had the latest version. That was a real pain to sort out.
