solder mask rendering with eagle board import widget;
I recently picked up a laser to start lasering out solder masks and thus far i have discovered that this should definitely be done before holes are drilled. the widget renders everything fine except for solder pads around the vias. in eagle i have it set to create thermals and everything appears to be good. maybe i’m missing something. any advice would be appreciated.
What workspace are you using Clinton?
Edit
I see from earlier post that you are on tinyg. So my idea was not pertinent.
@clinton Can you share a screenshot?
