So when working with the CNC machine running on the Tinyg v8 I am
So when working with the CNC machine running on the Tinyg v8 I am having issues with homing. It runs through the process but It doesn’t seem to remember the positions like when you send it to zero it doesn’t go to the correct positon same thing with going to its Max. Also how do I keep it from going past the limits when Jogging the machine is that even a possibility and finally how does chilipepper know the size of the part
Are you sure you haven’t set a Work Coordinate System offset in G54? Thus when you home to machine coords, the G54 coords then jump in and override? I leave G54 to 0,0,0 to avoid that confusion.
You can set soft limits in tinyg to stop from going off edge of cnc.
ChiliPeppr knows size of part by calculating max xyz when you drag in your gcode file.
