So this is giving me fits.
+Peter van der Walt I’ll have to run downstairs & check the smoothie config. I’ll report back soon.
+Peter van der Walt I have my acceleration at just 4000, although I have this too:
default_feed_rate 27000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 27000 # Default rate ( mm/minute ) for G0 moves
Mine could probably do with some tweaking when I get time to play around again.
Here is where I"m at right now. I made a hardware side change and went back to an original setup for the PWM pin and removed all of the extra test circuit that @raykholo and I were working on. I changed acceleration to 10,000 and tickler power to 0.13. At 0.14 I get a very faint line while 0.13 doesn’t show so this seemed an acceptable setting.
https://plus.google.com/photos/105504973000570609199/albums/6339463020446086033/6339463022482016466
Ok, instead of replying to both posts, I’ll focus on this one. I just flashed to the latest firmware from the edge branch. Going to see what that does
I have accel set to 6000
