So my k40 makes a loud screeching noise.
So my k40 makes a loud screeching noise. When It does I see that the beam is going toward the metal part in the tube towards the small brown wire. It does this sometimes, off on on. When it doesn’t make that noise it cuts great, when it does it cant hardly cut 2mm cardboard at 6ma and 20mms. Is the tube trashed?
I would say so, I suspect an intermittent short in the tube - causing the beam to deflect
Are any of the ebay replacement tubes any good?
I dont think I will replace with L.O. tube. I noticed now the 1 meter tube says "Note: This laser tube is not designed for the K40 machine. I know it use to say it was a replacement or upgrade.
Let us know how it works out
