So mad my new laser is literally 10 miles down the road and I
So mad my new laser is literally 10 miles down the road and I can’t get it till Friday. My stupid road I live on does not all big trucks so they have to put it on a smaller on to get it to me and the soonest is Friday
Can you rent a truck and pick it up yourself?
I could but that is money and time i don’t want to spend
What laser a K40? Do you have car? A couple of heavy blankets and a friend would get it into the back seat or your trunk ( if is packed in the card board box like mine was). Might need a rope or two to hold it in the truck though.
It’s a 250lbs k50 big blue eBay special
Ya I see that> I was just re-posting a " never mind" as I found your earlier post on the K50.
Well that does indeed suck.
I got the K50 in the back of my SUV.
Volvo xc90 for reference
@Nigel_Conroy just a quick question what is the actual size of the cutting bed I want to get either a honey comb or blade table ordered and want to make sure it’s not to small or to big
@3D_Laser
Probably a bit more then you want but here you go…
Red cross-hairs are extremes of laser head
Black circles are the threaded rods the bed moves up and down on
A new surface that was 21 in x 14 in would fit in nicely and cover the working area of the laser.
Something with adjustable leveling feet is a good idea as the surface of the table isn’t flat as it’s light aluminum
@Nigel_Conroy thanks I am ordering a blade bed from Ali express
@Nigel_Conroy I though about doing 21.5 by 17 so it is renting on the frame not the aluminum bed
@3D_Laser you’ll need to explain a bit more by what you mean?
21.5 would be very tight to insert in mine as it wouldn’t really fit in between the threaded rods
Unlike the k40 what you see on the computer screen is not what gets cut with the k50 ,change view to wire frame is closer to what gets cut,the weld fuction will become you new best friend
@Phillip_Conroy it’s finally here!
