So like i want to be able to change modes using an Wemos D1 mini pro. And when i connect to it i can pull up a page that will let me select the mode i want to change to but without it having to be connected to WiFi. Where would be a good place to start on something like that? Are there examples out there? What do i need to google to pull something up similar to that?
So you dont need a wifi connection to access the web server? I plan to use this away from home
Correct, you can use it in access point mode
Ok awesome. Ill try it out. Thanx!
