So I’m working on a new project - a pair of LED goggles with animated eyebrows. The eyebrows are run with servos, and those work wonderfully, if a tad bit noisy. The problem comes when I try to use FastSPI to run the LED rings. The servos start twitching, and the commands I use start not working at all. Remove FastSPI, everything works correctly.
I am just using the basic “Servo.h” that comes with the arduino install. Is there a better way to run them?
What pins are you using and what controller (arduino, teensy, etc…). Also it looks like the servo library uses some timers - so it may require interrupts - which writing the ws2811 and friends require disabling.
Arduino Uno, pins 6 + 7 for the servos, pin 8 for the LED rings.
Edit: From some cursory reading, the servo wants a signal every 20ms to define the position. Basically, a pulse every 20ms of between 1 and 2ms to define the position. So there’s some math involved as well to go from “20 degrees” to “1.08ms pulse”.
Some possible things throwing off - the disabling/reenabling of interrupts may be messing with the timer/timing of the servos - which I don’t have a good fix for at the moment. A less likely possibility is noise crossing from 8 to 6/7 messing with the servos.
As for whether the interrupts being off means you aren’t updating as often as you should or whether the timing of the updates is off, I can’t quite speak to that yet - I haven’t messed much with servos.
Feeling adventurous? I can give you a file to play with and see if it helps.
What version are you running on currently? Trying to anticipate how much change you’ll need to make. I’m going to shoot you a file to replace the one currently in your library with, my laptop is currently doing some processing where it’s using the camera so I can’t use it, but I’ll try to pull the test file together for you in a few.
I just upgraded to the latest version. Not an issue - there’s hardly any code in the servo test that I was using, so I don’t really mind if I have to start over entirely.
I actually did restart, and pulled some of my code from my helmet, for better interlacing of effects. the commands now work, but I am still getting the twitchiness - which is purely because it’s missing an interrupt. Better than it was!
So I’ve SORT of solved it. By detaching and re-attaching to the servos when drawing on the LEDs, I can minimize the twitching. There’s still a tiny bit, but it’s pretty close now. it just seems I can’t just attach to the servo, update it, and detach it, though. Which is a pain.
